Lights staying on after car shut off
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by TomInOregon, Jan 15, 2020.
  1. TomInOregon
    TomInOregon Junior Member
    Vernonia, OR
    Hello, I have been having interesting problems with my 2010 Prius 2.
    First, my interior overhead light stopped working when the doors are open. It still works when the switch is flipped on, but not when any of the doors are open. This problem has remained since it started several months ago.
    Next, the tail lights were staying on at about half brightness after the car was shut off. If I locked the car with the remote, the lights would stay on, but if I locked it with the key, the lights turned off. It did this a couple of times, then stopped doing it.
    My latest problem started Saturday night after I came home. When I parked it, the left (driver) side turn signal lights stayed on front and back. Not blinking, just staying on. If I turn the turn signal on, it blinks slightly brighter, but the filaments are getting constant power. I pulled the fuse for the turn signal and it made no difference. The bulbs stay on. Unfortunately, this caused the 12V battery to die on the car. I jump started it today and it is running now, but the turn signal lights are still on and the tail lights were on at half brightness initially, but have gone off now. I need to drive this to work, so need to get it fixed soon.
    It looks like the lighting issues may be a symptom of the 12V battery going bad, but I don't understand how a bad 12V battery will cause power to go to the turn signal or tail light bulbs with no fuse in. I am planning on replacing the 12V battery next payday, but are there any other suggestions to check in the meantime?
    Thanks,
    Tom
    52,362
    i'm thinking rodents have chewed some wiring somewhere, but just a wild guess.
  3. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    Check battery voltage
  4. TomInOregon
    Vernonia, OR
    I have no reason to believe there are any rodents anywhere near the car. The battery voltage was 12.3 this morning when I had to jump start it to go to work. Obviously it's over 14V when running. I'm going to replace the hazard flasher to see if that's the problem. Apparently it's under the dash above the steering column, which explains why I couldn't find it before. Now I just have to find one that works with regular bulbs.
  5. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    New working battery before anything else.
  6. tankyuong
    1,555
    662
    Central MO
    Voltage too low
  7. vlxerdon
    vlxerdon Junior Member
    Georgia
    Gotta go with the other posters here, 12 volt battery.
  8. Mafs
    Mafs New Member
    Netherlands
    Quick question, is 12,3 volts really too low?
    My Auris with the gen 3 engine also has around this voltage (out of the car). Inside car it's around 12,06 with interior lights on.
    No weird issues like the OP though.
  9. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    On borrowed time mi amigo.
  10. TomInOregon
    Vernonia, OR
    To be fair, the 12.3 volts was after sitting for 10 hours with 2 incandescent bulbs on. I was surprised it was that high after a steady, prolonged drain. I don't think the battery voltage being low is causing the lights to be on. The voltage is low because the lights stay on.
    We got the replacement flasher relay yesterday and my wife will get it changed out to see if that fixes the problem.
  11. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Hope the majority are correct and that it's that it just needs a new 12 volt.
    Because if that's NOT the problem, it get's potentially pretty complicated.
    Also my opinion is that unfortunately the potential of rodent damage exists for all of us.
    There are rodents around us.....everywhere...."shudder"?
    But I've read posts where people have had rodent problems parking in a garage, or outside...anywhere.
    Hopefully this ISN'T the case.
    Not super cheap, but replacing the 12 volt is among the easier, instant resolution possibilities.
  12. Mafs
    Mafs New Member
    Netherlands
    Gotcha, will be shopping for a new one soon!
    As for the OP, I would reckon it's not the battery for you, looking at voltages alone though, compared to my battery atleast.
  13. TomInOregon
    Vernonia, OR
    I figured out the problem! The Curt trailer wiring box failed internally allowing +12V to (sometimes) keep the taillights on, and (sometimes) keep one or both of the turn signals on steadily. I removed the fuse to the Curt box and it now works fine. We did change the battery, though since it was 10 years old and got fully drained (down to +3.4V) again.
    pjksr02, fuzzy1 and bisco like this.
  14. bisco
    52,362
    well done!(y)
    TomInOregon likes this.
  15. bisco
    52,362
    not that far off :p
  16. fuzzy1
    10,602
    A Prius needed a jump start at 12.3 V? :confused: :eek: That seems indicative of either another problem, or a voltmeter being off. From many many past posts, I though they still started quite well until the battery fell to somewhere in the very high 10s to mid 11s range.
    But I'm glad you located the problem, in the trailer light controller.
