Line level input to JBL amp
Discussion in 'Gen 3 Prius Audio and Electronics' started by Flaninacupboard, Oct 9, 2011.
  1. Flaninacupboard
    Flaninacupboard Senior Member
    1,297
    213
    Midlands - UK
    I'm trying to find a line level source for my sub/amp. I have the JBL system, and have a found the thread with pinout for high level connections. Does the JBL amp have a line level input i can tap into, or is it's input already high level from the stock headunit?
    Think we could do with a sticky on this topic...!
  2. GeoGeek
    GeoGeek Member
    360
    31
    Auburndale, FL
    The short answer is "no" unfortunately.
    The signal coming from the factory head unit to the JBL amp under the passenger seat is a digital signal. To get a suitable signal for an aftermarket amplifier you're going to need to work with the electronically crossed-over, equalized, and DSP'ed (time delayed) high level signal coming out of the JBL amp. There are a few ways to do this: some have used a device like the JL Audio SSi and CleanSweep...you could also use a processor like the Audison Bit One, the Rockford Fosgate ThreeSixty.2, Audio Control DQL-8....but probably the best tool for the job would be the JBL MS-8.
    The other option is to scrap the factory amp & head unit altogether and go with an aftermarket head unit like many folks on this forum have.
  3. Flaninacupboard
    1,297
    213
    Midlands - UK
    Ahh i see, i didn't consider it having a digital input. i don't suppose it's a standard S/PDIF signal so i could use a normal DAC on it?
    If not my sub amp does have level inputs so i guess i can use those instead.
  4. GeoGeek
    GeoGeek Member
    360
    31
    Auburndale, FL
    I'm not sure about the format of the digital signal. I've read about devices that let you jump into the signal path in a couple select German-made vehicles (BMW & Mercedes), but I haven't heard of a similar animal for Toyota.
    The hi-level inputs on your amp may be rather tricky, since none of the signals coming off the factory amp are full range and un-processed. I suspect that the 6x9's in the front doors are the closest to a true sub signal....ideally, you'd be feeding full range signal to the aftermarket amp.
  5. Radiospank
    Radiospank Member
    152
    70
    well this sucks I was hoping to keep the factory head and using a full signal to my amp/ sub.
    right now I'm using the outputs of the jbl amp but its sending an amplified signal causing my loc to clip very early
  6. Radiospank
    Radiospank Member
    152
    70
    nvm scratch that the amp outputs are fine to use but they do have the processing from the amp which may or may not be desirable. I haven't noticed anything unusual about the rear channel in terms of freq response for my subwoofer
