Linear solenoid valve offset code issues
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by MaskedCrocheter, Sep 2, 2024 at 1:33 AM.
  1. MaskedCrocheter
    MaskedCrocheter New Member
    Los Angeles
    I have a 2012 Prius v. We replaced the actuator and the brake booster pump assembly. OEM brand new parts. Brake lines were bled properly. Went to recalibrate everything and the codes for the linear solenoid valve offset (c1345 c1368 c1451) are going off. We're using a ADS 625x scanner which worked fine for the brake bleeds. We tried to recalibrate the solenoid but it isn't working (the brake lights on the dash didn't blink as they're supposed to). It was suggested that we do a memory reset but we're having trouble finding the option on the scanner. Does anyone have any knowledge of the scanner/situation or other suggestions?
