Liqui Moly 0W-20 Engine Oil
Discussion in 'Gen 3 Prius Main Forum' started by kamrul, May 9, 2021.
  1. kamrul
    kamrul Junior Member
    99
    17
    Bangladesh
    Does anyone have any experience using it? The link to the product is here Special Tec AA 0W-20
    This is not a fully synthetic oil as per the specifications. How detrimental a semi-synthetic oil would be to the engine?
    100K kilometers (~65K miles), 35-40°C (95-105F) summer.
  2. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    It is quite confusing sadly, synthetic vs semi-synthetic vs non-synthetic.
    The US is flexible on the definition of synthetic meaning highly refined dino oil can be called "synthetic", highly refined Group III base stock.
    In Germany there is more strict tolerance, so synthetic means PAO or Ester.
    So their semi-synthetic is probably closer in quality to our synthetic.
    It's more expensive than Mobil 1, so even though I have 2 jugs I'm afraid I never used them. (Call me cheap. Probably should have a long time ago since they have some sort of warranty for 1 yr)... JPEG_20210509_162554_6092962090475688751.jpg
    moto g(7) power ?
  3. privilege
    privilege Active Member
    659
    169
    Birmingham
    I bet someone can find fully synthetic (on the label) for cheaper than $20 a gallon, but I just use this.
  4. Mendel Leisk
    42,093
    Bangledesh you might want to go with a heavier weight, say 5W30 or 10W30.
    GardenWeasel, privilege and kamrul like this.
  5. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,542
    2,584
    Taylors, SC
    privilege likes this.
  6. Pulse07
    Pulse07 Active Member
    273
    140
    East Bay, California
    2020 Prius
    XLE AWD-e
    Take away here is change your oil. It doesn't matter what brand you use . There's no miracle oil that will last forever.
    kamrul, privilege and Mendel Leisk like this.
  7. Georgina Rudkus
    3,542
    2,584
    Taylors, SC
    But dirt and sludge will stay in the engine forever unless you remove it with the oil when you change it.
  8. privilege
    659
    169
    Birmingham
  9. privilege
    659
    169
    Birmingham
    how do you separate oil from dirt, and get the dirt to stay in the engine ?
    magic ?
  10. ASRDogman
    ASRDogman Senior Member
    7,931
    4,037
    ??? Who put dirt in the engine????
    Grit likes this.
  11. Georgina Rudkus
    3,542
    2,584
    Taylors, SC
    You put it in the engine every time that you use it.
    Regolith, detritis, dust or whatever you call it, comes into the air intake. The air filter doesn't capture everything.
    Grit likes this.
  12. Georgina Rudkus
    3,542
    2,584
    Taylors, SC
    Obviously, if you don't change oil, the dirt stays in the engine.
    Grit likes this.
  13. ASRDogman
    7,931
    4,037
  14. privilege
    659
    169
    Birmingham
    lol !
    for a moment I thought you were referring to sludge or similar garbage that is left behind after every oil change.
    yes, there is some of that in every engine... the ones with great designs have the flow across a magnet .. like the drain plug
  15. Ed Beaty
    Ed Beaty Active Member
    334
    311
    Salt Lake City
    "great designs have the flow across a magnet"
    Last time I checked, dirt (and/or sludge) doesn't stick to a magnet....
    ASRDogman likes this.
  16. ASRDogman
    7,931
    4,037
    It's a "special" magnet....
  17. RRxing
    RRxing Senior Member
    2,559
    1,833
    NEPA
    FREE SLUDGE MAGNET WITH EVERY FUEL SHARK!!!
    (While supplies last...)
    Ed Beaty and ASRDogman like this.
  18. edthefox5
    edthefox5 Senior Member
    10,096
    4,836
    Clearwater, Florida
    G2 motor is a very clean running engine if you have sludge your using some crappy oil or piston rings are blown and you have bad blowby. Nothing will fix that. Lots of those on this site.
    Grit likes this.
  19. kamrul
    99
    17
    Bangladesh
    I understand your point since the climate is really hot here during summer. I have been trying to follow the recommendations.
  20. kamrul
    99
    17
    Bangladesh
    Are you referring to the regular change period? Yes, I do that usually at around 4-5000 kilometers / 6 months mark.
