Liqui Moly Motor Oil Saver
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by PriusV17, Nov 25, 2022.
  1. PriusV17
    PriusV17 Active Member
    322
    164
    CA
    2017 Prius v wagon
    My 2017 is not burning oil that I am aware of. But all the talk of having to keep topping the motor oil might end up having a solution after all?
    Has anyone tried "Liqui Moly Motor Oil Saver". Amazon reviews are nearly 5 stars and some claim zero leaks after use. The bottle claims to start working after 500 miles.
    Is this the magic bottle to oil consumption? We are talking lots of 5 star reviews that claim it is.
    They also have the Anti-Friction version. I'm going to start adding both as 'preventive measure'.
    Amazon.com: Customer reviews: Liqui Moly 2020 Motor Oil Saver - 300 ml
    Not a single review from a Prius owner.
  2. Air_Boss
    Air_Boss Senior Member
    3,952
    1,083
    New Yawk
    LiquiMoly has been around since the 1960s as an engine, transmission, and transaxle anti-friction additive.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    Even if they carry the same company label........it is NOT a good idea to dump more than one additive at a time into your oil or gas.
    I do not think that 2017 models are afflicted with the excessive oil usage problem.
    Maybe because they don't have enough miles yet.
    Or maybe because those engines are of a different design.
    I suspect that someone else will clarify.
    IF and when you do start noticing increased oil usage, switching to a "high mileage" oil would be a better idea than making your own guess as to what might help the situation.
  4. Mendel Leisk
    38,727
    Nope.
    Air_Boss likes this.
  5. rjparker
    rjparker Tu Humilde Sirviente
    7,976
    4,717
    Texas Hill Country
    No. More likely to damage sensitive parts like your variable valve timing.
