listen to radio
Discussion in 'Gen 2 Prius Main Forum' started by pingman, May 17, 2007.
  1. pingman
    pingman New Member
    124
    is there a way to turn off engine/hybrid when you park but still have radio on? or do you have to power off car the press start with foot off brake pedal everytime
  2. Tom6850
    Tom6850 Retired
    898
    Leesburg, FL
    <div class='quotetop'>QUOTE(pingman @ May 17 2007, 07:07 AM) [snapback]444030[/snapback]</div>
    Thats the way I must do it. I don't think there is another way.
  3. Charles Suitt
    Charles Suitt Senior Member
    1,637
    16
    Dallas TX
    :) Howdy pingman
    Refer, please to your Owner's Manual, Pages 140-143 which clearly explain the 'Accessories' mode which will alow you to listen to the sound system without having the Hybrid system on. There's a wealth of helpful information in the Owner's Manual. Some information is not to be found in the Owner's Manual. PriusChat forum is a superior resource for practical, helpful information.
    The short answer: Press the POWER button without pressing the brake pedal.
  4. JimboK
    JimboK One owner, low mileage
    2,817
    187
    49
    Chesterfield, VA
    <div class='quotetop'>QUOTE(Charles Suitt @ May 17 2007, 01:32 PM) [snapback]444270[/snapback]</div>
    I think he wants to go straight from ON to Accessories mode without going completely off first.
    Pingman, assuming that's your goal, I don't know of any way to do it.
  5. pingman
    pingman New Member
    124
    <div class='quotetop'>QUOTE(JimboK @ May 17 2007, 01:08 PM) [snapback]444305[/snapback]</div>
    thats the goal and thanks for the advice on the manual thats why i ask here the manual is useless for the small details
  6. dmckinstry
    dmckinstry New Member
    1,034
    Cheney, WA (Near Spokane)
    <div class='quotetop'>QUOTE(Tom 6850 @ May 17 2007, 04:10 AM) [snapback]444032[/snapback]</div>
    I suspect the only other way is if you have EV mod installed. I use that to be sure the ICE doesn't go on, if I have a high enough SOC%.
    Dave M.
  7. harper42
    harper42 Member
    226
    This is something I've wondered about. While sitting, waiting for the grandkids after school, I like to listen to the radio. I've been keeping the car running, thinking that any drain on the battery would be taken car of, with the engine kicking in whenever necessary. What about listening in accessory mode? Is there going to be battery drain. Can I run my battery down this way? Why is it better to use accessory mode? Thanks for your help.
  8. Joe Bernard
    Joe Bernard New Member
    <div class='quotetop'>QUOTE(Charles Suitt @ May 17 2007, 12:32 PM) [snapback]444270[/snapback]</div>
    "Read your manual, do a search." How much bandwidth is wasted telling people not to waste bandwidth.
  9. David Beale
    David Beale Senior Member
    5,963
    1,982
    Edmonton Alberta
    <div class='quotetop'>QUOTE(dulcimer @ May 20 2007, 10:28 AM) [snapback]446145[/snapback]</div>
    You can run down the 12V battery in accessory mode. The radio consumes perhaps 2A max. and it's a 38 A-Hr battery. So you could probably listen for 14 hours before you'd have to worry about the car not starting. It charges right back up as soon as you enter ready mode (well, after some time). I don't think draining the battery is much of an issue.
    It's better to use accessory mode because you don't burn gasoline. If you need the A/C to run, then use ready mode but leave the transmission in Park (so the ICE will charge the traction battery). In ready mode the ICE can start and stop, burning gasoline.
    2 people like this.
  10. priustexasbob
    priustexasbob Member
    356
    86
    arrakis
    2015 Prius c
    thanks Charles and David, you both answered my question without having to ask it.
