Lithium batteries -- SAFE?
Discussion in 'Fred's House of Pancakes' started by cyberpriusII, Mar 6, 2023.
  1. cyberpriusII
    cyberpriusII Maybe it was the roses
    1,157
    1,840
    Hyampom
    I would hope so, considering how many there are of them out there, but the report of a Bronx apartment building burning this past weekend gave me pause...
    Anyway, I was going to post this in the battery lawn equipment thread, but thought it goes further than that.
    I have a couple of battery lawn tools and they have been lifesavers (well, I exaggerate...), but you get the idea.
    But, now I am a bit worried about their safety. I have one no-name aftermarket lawnmower battery I purchased from Amazon, as well as a few no-name (well, Audew and GooLOO) auto Jumppacks from Amazon, as well as batteries from a couple of different "major makers." Should I yawn and quit worrying -- or should they be locked into steel boxes when not in use.
    Yes I am joking a bit, but not much. In general, are these safe?
    kris
  2. Trollbait
    12,681
    Officials generic use of Li-ion battery for when they mean a battery of a scooter or bike isn't helping the fear. Taking NYC's mayor comment literally means leaving your phone and tablet outside.
    A battery for a mobility device like a scooter can hold a lot more energy than the battery in a phone. Both could catch fire, but the scooter fire is going to escalate faster. So more care should be taken with it, just like you take more care with a jug of gasoline vs a bottle of nail polish remover.
    Something to also consider with these fires in a city is the presence of rental scooters. Those things get abused. Then it is a gig worker that collects them up and chargers them,. Usually in their apartment. Some of these battery fires were cases of multiple scooters being charged off a power strip. They may not have been the true ignition source.
    There were potential electrical fire sources in the home before Li-ion powered phones came along. Cars were also quite able to ignite before EVs. Take care, but this isn't something to lose sleep over.
    cyberpriusII and Zythryn like this.
  3. Leadfoot J. McCoalroller
    8,147
    7,646
    Pennsylvania
    2018 Prius c
    The only situation I'd be on the lookout for is if an accident were to occur where the tool battery were hit particularly hard, fell very far, or were crushed somehow.
    When that happens, you want that battery to sleep outside, usually on a bit of concrete... just in case. The fires can start hours after the actual injury.
    Well I suppose there's also the case of counterfeits and off-brand replacements. They are sometimes extra-sensitive or just easier to damage.
    cyberpriusII and Trollbait like this.
  4. John321
    John321 Senior Member
    1,457
    1,405
    Kentucky
    #4 John321, Mar 6, 2023
  5. bisco
    52,390
    they are safe, just not 100%. like anything else in life there's a small risk you have to be willing to take, and as mentioned above, treat them sensibly
  6. Trollbait
    12,681
    Got curious. An article of the recent fire mentions that there were 400 battery fires in the city over the past four years. Another article states there have been 30 so far this year.
    In 2019 there were 8,231 fires in the Bronx, and 40,783 fires citywide.
    The OSHA document mentions charging below 0C causes damage that can lead to failure. Is this failure one that can result in a fire? I don't recall that being brought up with other sources of below freezing charging.
    Looks like implanted devices don't use the same lithium chemistry as typical Li-ion. Pacemakers use lithium-iodide, and solid state is now being used in such devices.
    Note: getting a posting error so removed all hyper links
    cyberpriusII likes this.
  7. ETC(SS)
    7,352
    In General......they are.
    Energy is energy.
    220v outlets -- SAFE?
    Gallon of gas -- SAFE?
    Propane tank -- SAFE?
    Xeico likes this.
  8. AntonyU21
    AntonyU21 New Member
    ca
    Lithium batteries are not safe, and there is also a possibility of explosion, but the probability is not so high. It can be said that all batteries are unsafe and there are risks. According to the data, although the probability of explosion of lithium batteries is very small, the risk of spontaneous combustion of lithium batteries is relatively high. However, lithium batteries purchased from famous products generally have no problems and have quality assurance
  9. ColoradoBoo
    ColoradoBoo Senior Member
    1,271
    879
    Monument, Colorado USA
    Yep, I have two shelves in my garage with numerous chargers for my power equipment and lights. (All use lithiums) I no longer leave batteries plugged in but take them out as soon as the light indicates they are recharged.
    Too many pictures of burned garages/homes from lithiums exploding while sitting in chargers....pretty alarming!
    cyberpriusII and Georgina Rudkus like this.
  10. bwilson4web
    16,366
    Lithium batteries are safe enough provided: (1) at least one terminal is covered with any form of insulation, and (2) keep them from getting very hot or freezing code. Heat causes the contents to expand and stress the cells as the chemicals seek to escape. Freezing cold can reduce their chemical activity. Just keep at least one of the terminal ends covered by tape or insulating cover, even plastic held with a rubber band or string, and they'll be safe.
  11. cyberpriusII
    1,157
    1,840
    Hyampom
    Well. O.K You have all convinced me. I just ordered a pair of battery-powered heated socks. Have been having terrible problems with cold feet after an old accident,
    kris
  12. Trollbait
    12,681
    Just don't go to bed wearing them.
    Don't know if there are foot versions, but I got my brother some reusable chemical hand warmers that recharge in a microwave.
  13. cyberpriusII
    1,157
    1,840
    Hyampom
    yikes, I was planning them for night wear. sexy, I know, but my feet are fine during the day, it's periods of long inactivity, like reading, watching TV or ...trying to sleep...
    kris
  14. Trollbait
    12,681
    It was an overly cautious warning, cause on the off chance something goes wrong, best not to be asleep for it. The vent tube to the HHR's battery, in the back like a Prius, was always broken, and never died from hydrogen sulfide poisoning. The Li-ion risk is approaching that rarity to me.
    I also though a heating pad, or small electric blanket would be better for sleeping.
    And don't you have dogs? Several of the little breeds came to exist to simply warm beds.
  15. cyberpriusII
    1,157
    1,840
    Hyampom
    Before my time, my father used to talk about bricks heated in the wood stove and then wrapped in layers of newspaper tucked into the bottom of the bed. The layers of paper were crisp by morning, but never any fires. LOL!
    Anything with an electric cord would not work because of tripping hazard, entanglement -- and the Trollbait memory is wonderful because I do have dogs, just not as many as I used to have.
    I do have two dogs at the moment. One is 115 pounds and the little one is 85 pounds -- Depending on the day, the larger dog outweighs me.,,,but no,,,,no dogs in bed :eek::eek::eek:.
    Well,you got my mind working,,,, I guess maybe a hot water bottle in bed? In the meantime, I plan to wear out the battery socks in the evening by doing absolutely nothing while wearing them, :D
    kris
  16. fuzzy1
    10,603
    The risk varies enormously among the different rechargeable lithium-ion chemistries. A proper discussion requires review of the particular chemistries under consideration. Cobalt is associated with the highest risks, iron-phosphate among the lowest.
    Today's lithium batteries shouldn't be putting out any meaningful amount of hydrogen sulfide, as sulfur is not one of their active ingredients.
    Lead-acid batteries do use sulfur, and certain failure modes can put out hydrogen sulfide, hence the vent tubes on the 12V batteries.
    Lithium-sulfur batteries do exist in the lab, and have been put to some very specialized uses. But the last I heard, they are not (yet) commercially available.
  17. bwilson4web
    16,366
    If the socks are AA or AAA battery powered, no problem. Charging the batteries has the higher risk. Discharge, especially moderate current won't be a problem.
    As an experiment wear the socks with battery and rubber band an unconnected on the socks. If after an hour or so both the in-use and taped batteries feel (or measure) the same temperature ... forget about ... you are perfectly safe.
    For absolute peace of mind, get NiMH batteries in the size the socks need. You will have to recharge more frequently, ~2x, compared to AA or AAA batteries, but there is very little risk unless the are shorted out with jumper. Even then, they will get pretty warm and then cool down when the charge is gone.
    We didn't really discuss recharging but there is a whole other thread we dive into that deep pool.
  18. bisco
    52,390
    i've had a pair of zippo lithium hand warmers for a few years that are wonderful.
    also a chinese iphone battery case that has performed flawlessly
  19. Trollbait
    12,681
    Am seeing slippers and bed booties on Amazon that are just heated up in the microwave.
    I was thinking of thermal runaway next to the skin.
  20. cyberpriusII
    1,157
    1,840
    Hyampom
    The socks I ordered came with two 7.4V 2200mAh Batteries.
    Used them last night. Even on high, the warmth they provided was minimal. And they were among the highest rated on numerous sites -- sketchy sites and non-sketchy. I will probably try them again tonight, after recharging the batteries, but not hopeful -- and no, did not wear them in bed.
