Lithium battery from Dr. Prius?
Discussion in 'Generation 1 Prius Discussion' started by WHCSC, Nov 11, 2021.
  1. WHCSC
    WHCSC Member
    277
    63
    Omaha, NE
    2003 Prius
    ammdb likes this.
  2. Tombukt2
    Tombukt2 Senior Member
    9,138
    1,586
    Durham NC
    I didn't think the cost was that high for the gen 1 and 2 I thought it was about 18 anyway that's a life po set up supposed to be pretty good
    SM-A715F ?
  3. Tombukt2
    9,138
    1,586
    Durham NC
    Was going to buy this exact same setup but they're out of stock and no end in sight to the shortage
    SM-A715F ?
  4. Rmay635703
    Rmay635703 Senior Member
    2,594
    1,612
    Somewhere in Wisconsin
    2013 Chevy Volt
    I didn’t know the Gen 1 had a Lithium solution
    given the state’s taxation methods a Gen 1 Prius is the best model to own as you can drive registration free as opposed to paying hybrid penalties
  5. bisco
    49,492
    WHCSC likes this.
  6. AzusaPrius
    AzusaPrius Senior Member
    1,878
    823
  7. nimblemotors
    nimblemotors Re Member
    115
    35
    Sacramento
    2002 Prius
    NiMH last a long time with high current they way it is handled by the Toyota system. Lithium at high current not as much.
    Now if they used Lithium Titanate it would outlast the car AND give high current.
    Given there is no EV mode for the gen1, I'd stick with the oem setup.
  8. drbojo
    drbojo Junior Member
    Frankfurt
    2002 Prius
    I
    I am looking for an Installation guide For the Gen1. Any suggestions?
  9. Tombukt2
    9,138
    1,586
    Durham NC
    You don't find any YouTube videos of changing an original Prius HV battery I know there's a few I'll have to go find the links again but right it's very similar to the gen 2 . But different enough that if you didn't do this kind of work you might need the pointers trim removal and all that sort of thing but it's pretty straightforward I'll see if I can dig up the links to the YouTube videos there's been several out there and I would say I would probably stick with the nickel metal hydride too I don't know what's available for the Gen 1 not really my cup of tea cute car but different enough I wish they would have made a coupe in the Gen 2.
