Lithium Prototype Test
Discussion in 'Gen 3 Prius Accessories and Modifications' started by AzusaPrius, Oct 26, 2020.
  1. AzusaPrius
    AzusaPrius Senior Member
    2,254
    942
    Just got a brand new set to replace my tired 15 year old hybrid traction battery. I will be installing them soon.
    icyrius, GG707, Minima Domum and 9 others like this.
  2. PriusCamper
    PriusCamper Senior Member
    13,440
    5,426
    Pacific Northwest, USA
    Yay!!! May we all be blessed with these soon!!! I've had one of these packs in my '07 for 48 hours now... Full report coming soon!!! Performance is improved in so many ways!!! Special thanks to @jacktheripper of Dr. Prius for years and years of hard work to get so close to the finish line of the first full on production order coming soon so everyone can enjoy the benefits of his hard work.
    #2 PriusCamper, Oct 26, 2020
  3. royrose
    royrose Senior Member
    1,389
    953
    Foot of Pikes Peak
    jacktheripper likes this.
  4. PriusCamper
    13,440
    5,426
    Yes, his little lithium packets are now inside prototype 3D printed modules. Precision of 3D printing is less precise than final production plastic modules will be but gives a basic sense of how they'll look and allows further testing before first big production order.
    jacktheripper and kenoarto like this.
  5. jacktheripper
    jacktheripper Senior Member
    284
    558
    yup, still tweaking the final 3D design, ex: the temperature sensor holder at the bottom of the case need to be tighter by 1.5mm
    I am printing a new case now just to confirm.
    jimontheocean, vvillovv, SFO and 4 others like this.
  6. Prius717
    Prius717 Junior Member
    51
    Lancaster County PA
    This is awesome! Looking forward to this. Any idea what this would cost?
  7. AzusaPrius
    2,254
    942
    Yes this is Dr Prius prototype and I can barely sleep just thinking about installing and driving around testing.
  8. AzusaPrius
    2,254
    942
    Already taking things apart preparing for tomorrows installation of Dr Prius Lithium prototype.
  9. PriusCamper
    13,440
    5,426
    Lol, Orange safety plug in and their terminals that connect the pack exposed... Be careful!!!
    And what are those white stickers on top of each module? I've not seen that in Gen3 packs before? Is that something you did or did it come like that?
  10. AzusaPrius
    2,254
    942
    I just unbolted everything to take it out, tomorrow I will pull the plug.
    The stickers are from whoever did the refurbished battery when I bought it.
    I had to replace one module and its been doing fine but it is old and tired.
    I will be careful when doing everything for sure and will post pictures.
    jacktheripper and PriusCamper like this.
  11. PriusCamper
    13,440
    5,426
    Thanks, that's what I figured those labels were from...
    I always pull the orange plug before I unbolt anything. It's the first thing I do after I access the spare tire area.
  12. AzusaPrius
    2,254
    942
    At last the Dr Prius Lithium prototype is installed!!!
    Took her for a 30 mile drive with no problems, before I was recently having to turn the fan higher to 3-4 speed when using the AC on Lo.
    Today I actually turn it up to 73F with the fan speed at one bar and the outside air was 75F.
    The AC was noticebly performing better.
    I was using Eco mode for the first 5 miles then put her in Power mode!!!
    At first start display showed full battery and only dropped one bar
    The whole time I drove her.
    Until I got on a flat road and tried to drain it using only battery.
    I got up to 52 mph before the ICE kicked on and thats when I noticed it dropped another bar.
    The battery quickly charged up to full within a couple minutes tops.
    Overall nothing but a big smile on my face as I drive the quickest prius in my area.
    Will post more as I use it.
    Im having problems uploading pictures right now.
  13. AzusaPrius
    2,254
    942
    Minima Domum and Tim Jones like this.
  14. AzusaPrius
    2,254
    942
  15. AzusaPrius
    2,254
    942
    Tim Jones likes this.
  16. AzusaPrius
    2,254
    942
    Turn on Dr Prius app right away.
    At the end of the 30 mile test the batteries never past 95F.
    I took 2 good inclined roads.
    They are more than a quarter mile each the battery only dropped one bar from full.
    #16 AzusaPrius, Oct 29, 2020
  17. vvillovv
    vvillovv Senior Member
    4,336
    1,518
    NY
    Man alive -- that block voltage graph makes it look like the modules are way out of balance. Than I see that the voltages are all at 18.3x so pretty close. I had to zoom way in to read um (block voltages), but it was well worth the effort.
    Thanks for all the pics and camper for hinting at the pouch size used in the modules.
  18. Rmay635703
    Rmay635703 Senior Member
    2,690
    1,725
    Somewhere in Wisconsin
    2013 Chevy Volt
    Is anyone testing this Lithium upgrade on a 2001 Prius?
  19. Tim Jones
    Tim Jones Senior Member
    1,760
    567
    SE Texas
    2011 Nissan LEAF
    audiodave likes this.
  20. TheChip
    TheChip Senior Member
    388
    1,210
    Misissippi
    Give EV mode a try. I was able to get over 3 miles in all electric, which is very good for a 2010 Gen3. The pack I replaced was barely able to get a single mile, although that pack was likely a bit worn out. I also appreciate how light weight the pack is, it makes removing the battery an incredibly easy job.
