Lithium traction battery degradation - 2012 plugin
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by willyag, Jan 18, 2018.
  1. willyag
    willyag Junior Member
    28
    Orlando, FL
    I hope my 2012 plugin lasts 200, 000 miles but I'm having doubts. At 54,000 miles the traction battery only gives me 6.7 miles and that is going down slowly by the month. That still gets me to the shopping center and back but only with about 1.5 miles left. Anyplace else I turn on the engine manually hoping to keep the battery from wearing down further. When I get to 5 miles left, I'm going to stop charging altogether. Can anyone direct me to where I can get information about replacing the lithium battery or rebuilding it?
    mjoo likes this.
  2. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    Search Prius Chat.
  3. davecook89t
    davecook89t Senior Member
    1,057
    789
    Washington State, Florida
    Four Touring
    How much of that is related to ambient (outside) temperature? I know you are in Orlando, so you don't experience the same kind of cold the rest of us get, but if you were looking at your range this morning (when it is close to freezing down there, according to my weather map), you would have probably seen 20% less than on a normal day.
    Data Daedalus likes this.
  4. fotomoto
    fotomoto Senior Member
    5,602
    3,778
    So. Texas
    If I keep my Energi long term, this is what I'm thinking about doing. I'll call it a "super hybrid". :whistle:
    Used plug-in batteries are reeeeeeeal cheap right now. I found several for the Volt (huge 16kwh battery) for less than $1,000. Heck, used gen 2 prius batteries cost more than that! Supply and demand.
    Here's the rub: most folks don't have the means to properly store a spare LiOn battery for months or years while waiting for their original to crap out. Hopefully a nice repair/rebuild cottage industry will develop just like it did for NiMh chemistries.
  5. gallde
    gallde Active Member
    238
    130
    Tarrytown, NY
    My 2012 with 60k still gives about 8 miles (without A/C turned on), and I live in a hilly area with cold winters and drive on high-speed roads always fully discharging. That would seem to be worst case, but your range is even less in a warm area with few hills. Do you have an extended warranty through which you can try to claim a defective battery?
  6. bisco
    49,379
    32 degrees in orlando this morning.:eek:
  7. Andyprius1
    2,327
    859
    Cool CA
    That’ll do it.
    Data Daedalus and davecook89t like this.
  8. bisco
    49,379
    have you owned it since new?
    without more info, we can't help you, except to say no one has ever had to replace a pip battery.
    except maybe one case when the car wouldn't go at all and dealer put a new one in under warranty.
  9. jerrymildred
    jerrymildred Senior Member
    11,508
    14,109
    Tampa, FL
    I'm showing about 10.5 miles predicted EV range on my 2013. It was 29° when I left for work this morning. It's a pretty demanding commute, too. Speed limits of 45-60 with lots and lots of stops, many too sudden to regenerate.
    bisco, Data Daedalus and Prodigyplace like this.
  10. Mendel Leisk
    38,648
    Can the dealership do "hybrid health check"* on the PIP battery? I think they charge around $100 for this? At least then you're not in the dark regarding battery status.
    * Google "Toyota hybrid health check" for more info. Toyota UK is promoting this, but it must be possible for North American dealerships to perform this too?
    #10 Mendel Leisk, Jan 18, 2018
    Data Daedalus, SFO and Aaron Vitolins like this.
  11. willyag
    28
    Orlando, FL
    My mileage went up to 7.7 this cold morning but I suspect that's due AC turned off. I'll look for used batteries but like you said- how to store? I'll check the warranty. It's cold for Orlando. Glad to know there are no reports of bad PIP batteries, explains the lack of replacement info. I can accept a "super hybrid" especially with today's gas prices as long as it keeps going. Finally thanks for the links to related threads and thanks for all the responses (I didn't expect so many). Good luck with all your Prius's.
    Data Daedalus and jerrymildred like this.
  12. Mendel Leisk
    38,648
    That's just nuts, 43F here right now.
    Data Daedalus, padroo and bisco like this.
  13. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    You’ve already headed south:).
    Now you just have to work on going west;).
    Data Daedalus, bisco and iplug like this.
  14. bisco
    49,379
    no, i'm just keeping a weather eye out. 29 january, God willing.
  15. Data Daedalus
    Data Daedalus Senior Member
    1,022
    1,183
    Wembley, London
    Seems about right for that kind of operational temperature. The EV range on that PiP always drops in winter. I’m of course assuming that’s 32 degrees Fahrenheit
    iPad ? Pro
  16. Data Daedalus
    1,022
    1,183
    Wembley, London
    Was that the Fahrenheit or Celsius scale?
    iPad ? Pro
    jerrymildred likes this.
  17. jerrymildred
    11,508
    14,109
    Tampa, FL
    U.S., so Fahrenheit scale. ;)
  18. QuantumFireball
    QuantumFireball Active Member
    419
    267
    Ireland
    The range estimation for me always drops by about a mile in winter, even though the effective range that I can drive in EV mode doesn't seem to change so much. I'm in a very temperate climate though, rarely goes below freezing in winter and summer averages are about 15C/60F. I've never heard the battery fans go on while driving (only when charging).
    I also lost significant range when one of the rear brake caliper slide pins seized - so if your rear brakes are making noise or wearing unevenly, be sure to check them out ASAP.
    willyag, Andyprius1 and jerrymildred like this.
  19. willyag
    28
    Orlando, FL
    So I had to go to the dealer for a recall and I asked for a quote to replace the battery. $11,200 after installation and taxes. That's equal to the current trade in value. I guess I'll keep driving it until it won't make it out of the driveway. Hope that's a long time from now. Just FYI.
  20. fotomoto
    5,602
    3,778
    So. Texas
    LOL. Stealers..... :whistle:
    A quick search on flea-bay, shows numerous used PIP batts ranging in price (with shipping) from $1200-2500 so you have options. Now the question becomes, how long can this LiOn chemistry sit without maintenance? By the time willyag and other PIP owners actually need or want a used replacement, will these still be good? :sleep:
