Little black hose
Discussion in 'Gen 2 Prius Main Forum' started by Sphil05, Jan 27, 2021.
  1. Sphil05
    Sphil05 New Member
    Pennsylvania
    I replaced my 12v optima battery, and noticed this little black hose that comes up through the floor in the back. I didn’t notice disconnecting it, and don’t see where it went. Can anyone tell me what this is, maybe just a vent? Also found there was an inch of water in the bottom of the well.
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    It is the vent for your 12 volt battery. Your optima had a vent don’t know what you bought.
    Try to address that rust if not it will eventually rot out and the bottom will fall out there’s a lot of weight on that area.
    Few posters that had happened to quite a hassle to fix it.
    It’s probably rotted under you spare tire too.
    the water drips right on the hybrid battery fan connector too and rots it out.
    That will throw a red triangle of death.
    good times
    Sphil05 likes this.
