Little known maintenance requirement
Discussion in 'Gen 2 Prius Main Forum' started by JayGoldstein, Mar 31, 2008.
  1. JayGoldstein
    JayGoldstein Member
    120
    Winnipeg, Manitoba, Canada
    Few Prius owners are aware that the tires on the Energy Monitor screen of their Multifunction Display should be rotated annually to equalize wear. A front to back rotation pattern is recommended.
    To help owners to remember to perform this task, Toyota suggests that the tires be rotated every April 1st.
  2. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    Jay
    Tee hee!
    Seriously, try heavy drinking. Works for me
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Are you sure? I recall a thread where an X pattern was recommended. One poster had his factory warranty voided by using a front to back pattern.
    Tom
  4. ForTheGlory
    ForTheGlory New Member
    296
    Maryland
    I'll have to get on that right away.
    On a different note (slightly related), where is the option to set the reference tire pressure for the TPMS? I scrolled through the various menus on the MFD for a couple of minutes and couldn't find it. Don't have the owner's manual handy.
  5. Rich96c4ce
    Rich96c4ce New Member
    55
    Southern Maryland
    Yeah, so why are we being told this on March 31st?
  6. Rich96c4ce
    55
    Southern Maryland
    The front to back pattern is what is shown in the Prius owner's manual, contrary to x-pattern that the Rubber and Tire Manufacturers Association recommends. That may be way the tire warrantee was denied. Someone should write to Toyota to get that cleared up.
  7. ravenmaniac
    ravenmaniac Senior Executive VP of Nothing
    156
    DC Metro Area
    Is the front to back pattern because those tires are directional and the Integrities that come stock on the car are not. Hmmm, I wonder if we should follow the manual or the tire expert's opinion on this one????
    I think this service is included in the 90k mile maintenance package too. Make sure your dealer does it for you...LOL!:)
  8. HardCase
    HardCase SilverPineMica, the green one
    408
    Kalispell, Montana
    Thanks for the reminder. I rotate my tires on all my vehicles every other oil-change, seems to work out fine.
  9. patsparks
    10,664
    567
    Adelaide South Australia
    Ha, it is April 1 here right now so get rotating.
  10. narf
    narf Active Member
    611
    44
    Colorado
    Four Touring
    However, the MFD wheels are very special. Not only do they spin for a second or so after the car stops but they are staggered, with the near side wheels using a five spoke design and the far side wheels being a four spoke design. (I wonder if that's the same on right hand drive versions?) Therefor, be sure to not use X pattern when rotating the MFD wheels, you could really screw up the stagger.
    :rolleyes:
  11. narf
    narf Active Member
    611
    44
    Colorado
    Four Touring
    Assuming this isn't just another silly MFD question, there is a button below the steering wheel that resets the TPMS to the current tire pressures. It's on the same bezel that holds the SKS defeat switch.
  12. ForTheGlory
    296
    Maryland
    Thanks, that's exactly the info I was looking for.
  13. Jack66
    Jack66 Kinda Jovial Member
    766
    Stafford, Virginia
    On par with the question of "Does a tree make a noise if it falls in the forest and no one hears it..." Do the MFD tires experience treadwear if I keep it on the energy screen?:)
  14. Steamboatsig
    Steamboatsig Member
    337
    Los Angeles
    2013 Prius Plug-in
    Laugh all you guys want, but the op gave good advice. Just make sure to check the muffler bearings and turn signal fluid while you are at it.
  15. TonyPSchaefer
    14,816
    2,498
    66
    Far-North Chicagoland
    After four years of not rotating the MFD tires, they are starting to show some uneven wear.
    Can anyone recommend a good replacement MFD tire? And how would a different tire affect my mileage?
  16. lesturner
    lesturner Taming the Dragon - Tennessee
    75
    Bremen, IN, USA
    There should be a reset button under the dash (below the steering column). There should be a button to turn off the Smart Key System and one to reset the TPMS.
  17. NorCal Rusty
    NorCal Rusty RatherBWakeboarding
    189
    Napa
    I overinflated my tires on the MFD and I had one go flat. I just can't figure out where the jack is? :doh:
  18. qbee42
    18,058
    3,074
    Northern Michigan
    I can't believe you went four years with those crappy OEM MFD tires. My MFD got stuck every time it snowed until I updated the tires.
    Tom
  19. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    I took the trim rings off my MFD tires. Looks MUCH better!!!
  20. NoMoShocks
    NoMoShocks Electrical Engineer
    1,292
    82
    Camas, WA
    The need to rotate tires is a myth. Mine rotate evey time I move the car. And yes, the MFD tires do look better with trim rings off.
