Location of Front Wiper Fluid Pump
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by sharpshin, Nov 13, 2008.
  1. sharpshin
    sharpshin New Member
    Kentucky
    I've read a few of the threads in which people have shared their troubles with front wiper fluid failing to distribute from the jets. I'm pretty confident that my front pump has gone bad on my 2007, but I don't know where the pump is or how to get to it to 1) see if it's clogged or 2) change it out.
    Could someone kindly help me locate the front pump so I can start troublshooting there?
    Thanks,
    John
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    Isn't the car still under warranty? If so, take it back to the dealer. Why do you think it's the pump?
  3. Patrick Wong
    18,200
    6,472
    Hi John,
    The windshield washer pump motor is located below the washer fluid reservoir. Have someone activate the washer function while you listen to see if the motor is working or not.
    Normally this issue would be covered under the 3 yr/36K mile warranty.
  4. sharpshin
    Kentucky
    Thanks, guys. I understand on the warranty. It's hard for me to get to the dealer since I live so far away so sometimes it's better for me to just order a part and fix things on my own.
