Location of headlight relay?
Discussion in 'Gen 3 Prius Technical Discussion' started by redprius10, Dec 17, 2024.
  1. redprius10
    redprius10 Junior Member
    Virginia
    I'm trying to identify the headlight relay in the engine compartment fuse box. The relays aren't labeled in the owner's manual. Also, can anyone confirm the part number as 90080-87024? The dealer gave me that number but when I look it up it says cooling fan relay. Thanks.
  2. ChapmanF
    18,522
    Low beams in your 2010 are fed directly by the "integration relay", the long white box down the side of the fuse box, which also feeds a number of other things.
    Brian1954 likes this.
