Lock button on one FOB doesn't work
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by coyote2, Aug 3, 2023.
  1. coyote2
    coyote2 Member
    147
    36
    The Lock button on one of my FOBs stopped working.
    I swapped CR2030's with the AOK FOB and that didn't help. I pulled up the rubber cover and everything looks the same on both FOBs. The Unlock button works AOK.
    Is there a fix? (If not, thankfully the problematic FOB still can operate the Lock buttons on the doors.)
  2. Tombukt2
    Tombukt2 Senior Member
    13,537
    2,439
    Durham NC
    So when you peeled back the rubber of the non-working fob and you hit the button that seems to not be working does it click and make the red light come on on the remote? The other two buttons make a distinct click and you see the red light up correct?
  3. coyote2
    coyote2 Member
    147
    36
    Yes the button that seems to not be working does click and make the red light near it come on. (The other buttons also make the red light come on.) Sorry I neglected to mention this data.
