lockdown won't open the doors
Discussion in 'Gen 4 Prius Main Forum' started by husami, Apr 28, 2020.
  1. husami
    husami Junior Member
    50
    Cincinnati, Ohio
    2017 with smart proximity key has been setting about 10 days. The doors won't unlock. The keyfob light comes on. I tried the emergency key on driver side but for some reason it won't unlock the door. Is there another way to open the door? my suspicion is that the 12v battery died.
  2. Mendel Leisk
    39,016
    The physical key should work. I would (gently) persevere with it. More'n like the 12 volt's the culprit.
    Tyfly and krmcg like this.
  3. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    The door lock probably needs a bit of lubrication to get the physical key to work. my preferred lube for locks is silicone spray.
  4. jerrymildred
    jerrymildred Senior Member
    11,518
    14,127
    Tampa, FL
    This is precisely why the fob has a mechanical key in it.
    Raytheeagle likes this.
  5. pianewman
    pianewman Active Member
    264
    183
    DallasFortWorthTEXASregion
    2018 Prius
    My preference is powdered graphite. I've used silicone, as well.
    kithmo likes this.
  6. ChapmanF
    16,058
    Did you buy the car new, or happen to try the physical key at the time of purchase to make sure it worked then?
    Inconvenient if it is cut for a different car.
  7. The Professor
    The Professor Senior Member
    598
    809
    UK
    Excel
    I've had to use the physical key on my Prius, previous vehicle, and an old Toyota Yaris. Each time I thought the lock wasn't working and the door didn't open. Turned out, as people have said or implied above, that was just REALLY stiff. I wouldn't use enough force to break stuff, but definitely apply a bit of thin or penetrating lube. While technically not a lube, WD40 is a product you may well have to hand and is good for stuff like this as it squirts into the lock and penetrates pretty well.
    Graphite is a good lube, but it's not going to penetrate well in this context.
    If you get it working, apply a small amount of general purpose (e.g. 3 in 1) oil to the lock and/or key and lock/unlock it several times.
  8. fuzzy1
    10,286
    WD40 is good for initial use getting the thing open. It just doesn't stay around for longer term lubrication because it evaporates away, so something else is needed after that.
  9. The Professor
    598
    809
    UK
    Excel
    Exactly. I should have really explained why I added the last line in my post about oiling afterwards.
    fuzzy1 likes this.
  10. pianewman
    264
    183
    2018 Prius
    Hmm...I used to keep my cars a LOOONG time (12-15 years...pre-electronic overload with fragile 22 guage wiring...), and I always regretted ANY use of 3in1 or any oily substance in locks. IMHO, it's just too prone to getting gummy.
  11. Mendel Leisk
    39,016
    Maybe silicone spray? Keep it contained though, don't let it dribble down the exterior paint. I forget exactly why, but it's bad for something. Maybe if you ever need a repaint?
    kithmo likes this.
