locked out of my new prime
Discussion in 'Prime Main Forum (2017-2022)' started by C 1 Operator, Dec 26, 2018.
  1. C 1 Operator
    C 1 Operator Junior Member
    both fobs are in the car and i cant open the doors or the trunk??? Im i actually locked out? i put my finger on those two little nubs on the handle and nothing?? help there is a blue light flashing down by the left knee area the dealership said the alarm was deactivated when we left the lot today
  2. Tideland Prius
    16,128
    You do have an actual physical key that can open the door (although it may set off the alarm if you have an aftermarket alarm installed by the dealer).
  3. C 1 Operator
    physical key? we have two fobs and by the looks of them, there is no key.
  4. C 1 Operator
    ok found the key, idiot newb salesguy didnt disable the lot alarm
  5. Tideland Prius
    16,128
    Lol ok. I was gonna day. Two Prius owner... you should’ve found the mechanical key by now :).
  6. C 1 Operator
    ah ha actually i registered here awhile ago, while deciding if i wanted a prius and never got one. this is my or shall i say my wifes first.
    pjm877, Tideland Prius and bisco like this.
  7. Salamander_King
    Salamander_King Senior Member
    10,970
    8,853
    New England
    Welcome.
    Just curious, how did you manage to open the locked door with both fobs inside of the car? The physical key is in the fob. I assumed they are also locked inside of the car.
    Mendel Leisk and bisco like this.
  8. jerrymildred
    jerrymildred Senior Member
    11,508
    14,109
    Tampa, FL
    Interesting! So, the Prime lets you lock your fob in the car? My wife often brings along her fob for my PiP when we travel together. And almost as often, she leaves it in the car. When I try to lock it, the car complains loudly and refuses to lock.
    My fob is always in my right front pocket if it's not on my desk. So far, I've never left that particular pocket in the car.
    benagi likes this.
  9. Salamander_King
    10,970
    8,853
    New England
    I was wondering about that too. It will not let you lock the key using the outside doorknob, but someone said you can still lock the door from inside power lock. I have not confirmed that yet.
    jerrymildred likes this.
  10. C 1 Operator
    no dont think so, what happened was post # 4 dealership alarm didnt get deactivated before i left the lot. that was the blinking blue light i was seeing.
  11. Salamander_King
    10,970
    8,853
    New England
    You might want to change your profile to reflect your new PRIME you now drive.
  12. C 1 Operator
    the salesman came to my house, with a way to enter the car, then placed the chip into the lot alarm, good to go
    jerrymildred and Tideland Prius like this.
  13. Tideland Prius
    16,128
    Sweet. Glad to hear the problem has been resolved.
    Hopefully the Smart Key System works now. (Not just the mechanical key or remote keyless entry)
  14. MikeDee
    MikeDee Senior Member
    1,550
    590
    San Francisco Bay Area
    How many fobs are you supposed to get with the car? I only got one (I think).
  15. Elektroingenieur
    2,515
    3,258
    Three Touring
    Two is usual. In any case, unless you’ve agreed otherwise, you should receive as many keys as are registered to the car, which can be checked using a Toyota Techstream diagnostic system (or third-party equivalent).
    Even if you don’t plan to use the second key regularly, it’s good to have and keep in a safe place, since it’s easier to replace a lost key if at least one working key is still available.
  16. MikeDee
    1,550
    590
    False alarm, found the other fob in the safe. Whew!
  17. huskers
    huskers Senior Member
    2,543
    2,486
    Nebraska
    I did not think it was possible to lock the car with a FOB inside.
  18. CharlesH
    2,785
    1,152
    Roseville, CA
    Not just easier; much less expensive if you have a key to copy. For the first generation PlugIn, if you lost all the keys, you had to actually replace the security module in the car ($$$). Now they can re-program it with new keys, but they still charge an arm and a leg to do it, as opposed to just an arm OR a leg to copy a working key :) .
  19. PT Guy
    PT Guy Senior Member
    1,085
    710
    Washington, the state
    If one does need a new key fob, a local locksmith can supply and program one for about half what the dealership charges.
