Locked right front wheel?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by mudrat, Jul 11, 2021.
  1. mudrat
    mudrat New Member
    Ontario
    Hi there,
    I have just received a 2005 Prius for my daughter. In checking it out, getting ready for inspection, I noticed I can not rotate the front right wheel. With front jacked up and both wheels off the ground, transmission in neutral and brake pads pushed back off the rotor, I can not spin the right wheel. Left spins easily.
    Is this normal?
    49,446
    frozen hub bearing?
  3. ChapmanF
    15,569
    Abby Normal.
  4. mr_guy_mann
    mr_guy_mann Senior Member
    3,461
    1,505
    NJ-USA
    I have seen any number of brake problems causing moderate to severe wheel drag, and I have seen even more worn, noisy, and loose hub bearings; but I can't recall EVER having wheel drag caused by a bearing (or cv axle).
