Locking without the Horn
Discussion in 'Prius v Technical Discussion' started by Winnipegger, Mar 21, 2012.
  1. Winnipegger
    Winnipegger New Member
    Winnipeg
    Is there a way to disable the horn honking when I lock the car? It doesn't honk when I unlock it, I'd love the same when I lock it. I didn't understand the Gen II Prius discussion on it and I can't find info anywhere else. Thanks!
  2. Keiichi
    Keiichi Active Member
    808
    79
    Goleta
    The horn shouldn't be honking for the Lock/unlocking for the Prius v. It should 'beep'. At least, on the Prius v I have does not honk and it is the stock sks.
  3. Winnipegger
    Winnipeg
    I like to think it shouldn't be too. Any idea how to change that?
  4. Keiichi
    808
    79
    Goleta
    No idea, since again, mine, out of the dealership was beeping, not honking for the alarm... So no idea why yours is using the car horn.
  5. h00ktern
    h00ktern Member
    134
    40
    If it is similar to the regular Gen3 (which I believe to be the case,) then yes, you can lower the volume, or mute it completely using Techstream. I did it on mine...
  6. Wanderer
    Wanderer Hybrid neophyte
    366
    39
    Cold country
  7. bisco
    49,489
    my dodge does that, i hate it. when did toyota change from the electronic beep?
  8. Winnipegger
    Winnipeg
    What is Techstream?
  9. Wanderer
    366
    39
    Cold country
    It appears to be a scan tool from Toyota. This software (or other device you will see mentioned such as ELM or scanguage) interfaces with the car's computer to change the items possible. Personally I'd ask the dealer to do it this close to purchase. I had the back up beep being disabled as a condition of sale but had to tell them how. (sad)
    W
  10. Winnipegger
    Winnipeg
    Just talked to the salesman. He said to pop in and a tech would take care of it. Thanks everyone.
  11. RichardAK
    RichardAK Member
    121
    Fairbanks, AK
    My Dodge used to do that but it was easy to change using a combination of the remote and the ignition key. I put up with it for one day before looking for a way to change the behavior. It was in the manual.
