Log in issues!!!
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by C56spd, Nov 17, 2011.
  1. C56spd
    C56spd New Member
    32
    Green Bay, Wi
    Is anyone else having log in issues? I have been trying since 12:05 and it will not take my username or e-mail. I have been trying to recover password but it keeps giving me a odd error issue.
    HELP
  2. theiding
    theiding New Member
    31
    Alameda, CA
    Had the same issue. Closing all browsers and starting over fixed it.
  3. RiverRat
    RiverRat Junior Member
    24
    Huntington Beach CA
    Had a problem with using IE, used Google Crome Browswer instead.
  4. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    I made the mistake of trying to configure prior to logging in. The login from the configuration screen wouldn't work. Logging in first and then configuring worked.
  5. H2OSkier
    H2OSkier Member
    276
    16
    I had to go to Chrome to get it to work. Both IE and Firebox didn't work. But I was still able to get a car @ 9:40 pst
  6. NYPrius1
    NYPrius1 Active Member
    1,181
    125
    Middletown, NY
    Still Trying No Luck So Far!
  7. bisco
    49,399
    my screen said 'sold out on line'.
  8. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    From Toyota if you're experiencing issues:
    The problem is an open bug where customers who have previously logged into the order site can error out upon log-in, as there is a caching issue related to it.
  9. NYPrius1
    1,181
    125
    Middletown, NY
    I tried both neither works for me. :mad:
  10. NYPrius1
    1,181
    125
    Middletown, NY
    Mark,
    I tried everything!
    I log in and get a frozen screen.
    or
    I hit configure and get a frozen screen.
    I have cleared the catch , rebooted, had Norton 360 clear history & all Temp Files. Still No Luck. I am using Firefox will try IE.
  11. jtse818818
    jtse818818 New Member
    I tried to login using IE and it never worked. Switched to Chrome and was able to login without any issues and placed an order. It might be too late anyways....preorders are all sold out.
  12. plchung
    plchung Junior Member
    72
    Orange County, CA
    same thing happened here. IE never worked. Chrome is a charm. I am glad that I placed an order.
  13. NYPrius1
    1,181
    125
    Middletown, NY
    I went in with IE It worked I THINK??
    I ordered everything BUT there was no place to order the interior color.
    I hit select dealer that worked.
    I hit submit order and a screen came up with notes - But I could not scroll down to the bottom. So I Assume I Ordered the PIP.
    BUT DID I? Only Toyota knows for sure.
    So Far this is the second time I have ordered this way.
    Back in 09 for the GEN 3 and now the PIP.
    Both have been a mess. Both had log in issues and ordering Issues.
    For such a large company How Can This Be
  14. NYPrius1
    1,181
    125
    Middletown, NY
    So Did I Order A PIP Today - I Have No Idea.
    After trying all day in Firefox and Clearing The Catch - Rebooting - and Even using Norton 360 to clear all history & Temp Files No Luck. :eek:
    Than
    I went in with IE It worked I THINK?? :confused:
    I ordered everything BUT there was no place to order the interior color. :juggle:
    I hit select dealer that worked. :rockon:
    I hit submit order and a screen came up with notes - But I could not scroll down to the bottom. So I Assume I Ordered the PIP. :hand:
    BUT DID I? Only Toyota knows for sure. :confused:
    Back in 09 for the GEN 3 and now the PIP. :nono:
    Both have been a mess. Both had log in issues and ordering Issues. :hurt:
    For such a large company How Can This Be :noidea:__________________
  15. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    Re: So Did I Order A PIP Today - I Have No Idea.
    When you log in right now at the very top is there a tab that says My Order (should be after prius plug in hybrid home and configure your plug-in)?
    If you do and click on the my order tab and have a confirmation you have a place in line. Did you confirm after your dealer did what he should and log back in to confirm and 'sign' by typing your name in and hitting submit? If so and the screen right now says Final approved status then yes, you're good to go.
    Also, no interior color choice as there is none. Only one interior choice, no choosing.
  16. jtse818818
    You should get an email notification to confirm your order if you have placed your order successfully. If you don't get an email confirmation, it is v. likely that the order didn't make it.
  17. NYPrius1
    1,181
    125
    Middletown, NY
    Just got the confirmation Email. :cheer2:
    I will try and select color of interior with the dealer or at least find out what color I will get. :(
    That and price will make my decision. :mod:
  18. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    You definitely have to get to the bottom of that pop up window, check a box, and fill in your first and last names.
  19. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    I thought it only came in one interior color (dark grey, black?).
  20. pfile
    pfile Member
    319
    35
    bay area, ca
    there might be a choice of interiors for the advanced model... can't remember.
