Long beep when opening the rear hatch
Discussion in 'Gen 5 Prius Main Forum' started by mannymendez25, Oct 4, 2025 at 10:38 AM.
  1. mannymendez25
    mannymendez25 Member
    61
    35
    Miami
    2020 Prius
    I have noticed recently that there is a long beep when opening up the rear hatch. It doesn't happen all the time. When opening the hatch, I typically get a beep, beep-beep. Sometimes, I get a beep, beeeeeeeeeeeep.
    I can't replicate it but it typically happens when I am getting out of the drivers seat and press the hatch button on the dashboard.
    Has anyone experiences this? What does that extra-long beep mean?
  2. RandyPete
    RandyPete Active Member
    401
    165
    Santa Margarita, CA, USA
    2024 Prius Prime
    XSE
    On the front door, two beeps means door was just unlocked. One beep means door was just locked.
  3. VelvetFoot
    VelvetFoot Member
    208
    New York State
    2026 Prius
    Are these beeps coming from inside or outside the car?
    edit: I just perused the manual. Do you have a power 'back door'? Could have something to do with that.
    If so, you'll have to read the manual, I can't figure it out, and I'm not getting the power option so there's no need. :)
    #3 VelvetFoot, Oct 7, 2025 at 5:27 PM
  4. RandyPete
    401
    165
    2024 Prius Prime
    XSE
    Its complicated ! If you have power back door it gets even more complicated. I suggest you get your owners manual out, or a pdf copy of it, and figure out your particular situation.
    #4 RandyPete, Oct 7, 2025 at 6:05 PM
  5. RandyPete
    401
    165
    2024 Prius Prime
    XSE
    oops. Do you have a gen 5 prius or a 2020 prius implied by your signature/profile. If 2020 prius, try posting to the 2020 prius group. Good luck.
    #5 RandyPete, Oct 7, 2025 at 6:17 PM
    GcinFl and Brian1954 like this.
