Long FT
Discussion in 'Prius v Main Forum' started by John Traynor, Aug 13, 2024.
  1. John Traynor
    John Traynor Junior Member
    23
    Long FT on a Prius v 2012. Unserviced EGR or intake manifold (I know, I know) running pretty smooth.
    I understand the basics of fuel trim in a caveman kind of way.
    I’m running min 5- max 8% which is not enough to trigger an error but enough to say I have some issues.
    I can’t afford to do everything at once.
    What would you do first?
    Injectors?
  2. MAX2
    MAX2 Member
    371
    88
    Third Rock from the Sun
    Do you constantly monitor the value Long FT using diagnostic programs?
    When did this “problem” appear?
    vvillovv likes this.
  3. vvillovv
    vvillovv Senior Member
    3,898
    1,338
    NY
    Unless you've already done the plugs, that's a good place to start, without any expectations of it producing any L or S FT difference. kiss philosophy - get your fingers or $ in the game and start monitoring.
    read the full manual
    all awhile u adjust for age and conditions
