Long Life Coolant mix with Super Life Coolant on Gen3
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Tekken, Aug 11, 2019.
  1. Tekken
    Tekken Member
    257
    77
    Los Angeles, California
    A search showing Gen 3 can be use with Long Life Coolant but can only last 30K miles while Super Long Life Coolant last 50K miles.
    Since my 2013 Prius had Super Long Life Coolant in system. Even if I drain and refill with LLC on my 2013 prius, I could mixed with SLLC and LLC in my coolant system. That's no way to completely drain all the SLLC out on inventer and engine right?
    I purchase the LLC on amazon by mistake, should I use it? It need be mix 50/50 with distill water.
    I also has asked Toyota Dealer, they offer LLC and SLLC. for 2013 Prius.
  2. RRxing
    RRxing Senior Member
    2,520
    1,791
    NEPA
    Both the 2013 and 2017 Maintenance Guides state that SLLC should be replaced at 100,000 miles.
  3. Patrick Wong
    18,200
    6,474
    This is correct. However as already pointed out, the change interval for the factory fill is 100K miles.
    It is OK to mix the LLC and SLLC. It is correct that the engine coolant loop will contain some old coolant after a drain, perhaps 1/3 of the total capacity. The inverter/transaxle will mostly be drained. You can use the LLC if you are willing to observe the 30K mile change interval.
