Long shot.
Discussion in 'Gen 3 Prius Audio and Electronics' started by De3mx, Jan 4, 2022.
  1. De3mx
    De3mx Junior Member
    United Kingdom
    Hi all,
    The problem started with 10a fuses popping on the interior lighting circuit.
    Just had my 2012 Prius in to an auto electrician and this (the photos) was identified as the probable cause.
    The AE says it looks like a diode pack, but has no idea what it’s purpose is. He has removed and bridged it and its absence has not thrown up any other issues.
    Anybody know what this was for?
    Many Thanks in Advance. :)
  2. StarCaller
    StarCaller Senior Member
    1,246
    697
    Cedar Crest, NM, USA
    if the guy thinks it's a diode pack, why would he just bridge it?
    might not be the best thing having the current flow in the wrong direction /
  3. ChapmanF
    15,617
    Did he give any info at all on where in the car he collected that from? Did you happen to see where?
  4. Elektroingenieur
    2,515
    3,259
    Three Touring
    From the “10962” marked on the housing (Toyota part number 90980-10962) and the yellow and violet colors of the wires, the Electrical Wiring Diagram (more info) shows it’s connector L91, Diode (Front Courtesy Light LH), part of the door courtesy light circuit. This isolation diode is in the circuit because it’s also wired to the FLCY (front door courtesy light switch LH input) terminal of the main body ECU.
    I’d suggest replacing it, for which you’d also need two repair wires (pre-terminated pigtails), 82998-12340; two splice sleeves, 82999-52020; and two heat-shrink sleeves, 82999-30010.
    StarCaller likes this.
  5. StarCaller
    1,246
    697
    hard to top that answer / (y)
