Long story : P0AC0, P3000, P3004
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Pyho, Nov 3, 2020.
  1. Pyho
    Pyho Junior Member
    31
    Bordeaux, France
    Hello from a french Priusman !
    I bought a used 2008 Prius 2 in july with 82,000km/51,000 miles and drove it 1000km/600miles before having problems.
    August 2020 : with OBD2 and Torque I searched for errors and it gave me P0AFA and P0AC0.
    So I took the battery apart and cleaned up the corrosion. Check the condition of all sensors and the ECU box. Each cell of the battery has been tested with a multimeter (voltage and resistance), then under voltage with a headlight bulb. She is fine.
    I put everything together and the car ran perfectly for 400km/230 miles.
    September 2020 : new error codes P0A90, P3000 et P3004. Helpless, I go to Toyota dealership and ask for a diagnostic : dead inverter. Ouch ! Repair costs : 3420€/4000$.
    Desperate I accept and tell myself that this will definitely solve the problem.
    October 2020 : After 6 weeks without a car, Toyota returns my Prius with a new inverter and it droves fine. Two days later I go shopping and when I start the car the error lights come on! OBD2 and Torque shows errors P0AC0, P3000 and P3004.
    Now I don't know what to do. This car is a disaster.
    The voltage of the 12v battery at rest is 12.45v. Torque and Dr Prius shows me all good battery elements.
    Maybe the HV ECU box is the culprit? What do you think ?
    Thanks for your help
    51,141
    no return to toyota after two days?
  3. Pyho
    Pyho Junior Member
    31
    Bordeaux, France
    The Prius has just returned yesterday for a diagnostic at Toyota Dealership. This time the technician accuses the ECU box which is next to the hybrid battery. He would also have noticed humidity in the trunk so will proceed to further check the harnesses and connectors this Friday.
    To be continued...
  4. PriusCamper
    PriusCamper Senior Member
    12,058
    4,893
    Pacific Northwest, USA
    I'd try to get some of your money back / report them to authorities for selling you an inverter you didn't need.
    The source of you problem is the corrosion where the voltage sensing harness plugs into the ECU.
    I see it all the time with those error code numbers. Probably the most common hybrid battery problem for cars in a wet climate. I can usually clean the corrosion off the plug and sandpaper on the pins to solve it.
    In more severe cases it shorts out the ECU so you just put a used one in for US $50 and sometimes I replace plug "wire Frame No. 2" which also costs US $50 and charge a few hours for labor. Very low cost repair that Toyota dealership won't do until they're done selling you expensive stuff you don't need.
    And because of this nature of dealerships They'll probably tell you that you need a new ECU just to steal another $800 US. Find a local mechanic you trust... Never take an old car to a dealership, they rip you off almost every time.
    Pyho likes this.
  5. Pyho
    Pyho Junior Member
    31
    Bordeaux, France
    Thank a lot @PriusCamper!
    Corrosion in ECU and harness plugs
    I cleaned it in August and the car ran well for about 400 miles before showing again P0AC0, P0AFA. But I really have the feeling too that there is a problem with that because the car spent all his life not far from the ocean (salt and humidity in the air). So maybe the wire frame n°2 is faulty.
    Toyota dealership
    I told them that I don't understand how they can give me the car back with new errors despite a recent expensive intervention on the inverter. On the bill it's written "Test of the car on the road after repair" and they surely did not! Otherwise they would have detected the P0AC0. Car is currently being tested again and mechanic is searching for problems with harness and connectors. I see that they feel a bit guilty in their attitude even if they will never say it.
    In short, I'm waiting for their final verdict but I won't buy anything from them anymore! I'm also opening a litigation thanks to the
    legal protection included in my insurance contract. Wish I can get my money back...
    PriusCamper likes this.
  6. Pyho
    Pyho Junior Member
    31
    Bordeaux, France
    Okay final answer from Toyota Stealership : ECU is failing (the one next to the NiMH battery pack).
    They refused to admit that there was a misdiagnosis on their part. No refund. No guilt. No support.
    Worse, they ask me 900 €/1070$ more to change the ECU. Of course I declined.
    I am absolutely frustrated and pissed off. :mad::mad::mad: Never had such experience of incompetence and bad faith.
    It's time for legal proceedings now! ...
  7. fotomoto
    fotomoto Senior Member
    5,629
    3,802
    So. Texas
    Check under the spare tire and the 12v battery location for standing water or evidence of such. Water leakage from the top of the hatch is common.
  8. PriusCamper
    12,058
    4,893
    you're lucky you don't live in the US where they've spent the past 40 years eliminating any consumer protection laws that get in the way of ripping people off.
    I'd recommend trying to find a hybrid battery rebuilder or wrecking yard for a used battery ECU... They're abundant and inexpensive.
  9. Pyho
    Pyho Junior Member
    31
    Bordeaux, France
    @fotomoto no trace of water found. I did inspect it too.
    @PriusCamper I give a try. It will take weeks but I still have a chance to be partially refund or receive money to repare the ECU with a brand new OEM.
    Finding a used battery ECU for Prius 2 in France is rare and expensive. Toyota sold so many more Prius 1, 2 and 3 in US!
    In general Asian car brands are not the most frequent cars you can see here. However Peugeot, Renault, Citroën, Volkswagen are everywhere.
    #9 Pyho, Nov 6, 2020
  10. PriusCamper
    12,058
    4,893
    If you can figure out the shipping I'll send you one for $50, but I'm running low on them so see if there's an easier way first.
    Pyho likes this.
  11. SFO
    SFO Senior Member
    5,302
    4,245
    Northern California
    Try this link : http://en.bildelsbasen.se/
  12. Pyho
    Pyho Junior Member
    31
    Bordeaux, France
    @PriusCamper I'm ok if you can sell me the ECU and I will pay the expedition.
    My original ECU has the reference 89890-47092.
    @SFO I had a look. My god the prices are crazy and no ECU found. Swedish currency is expensive/high.
  13. bisco
    51,141
    this is the downside of high tech cars, few know how to diagnose and repair properly.
    it's an emerging market, like computers in the 80's.
  14. Pyho
    Pyho Junior Member
    31
    Bordeaux, France
    I ordered a brand new Toyota Wireframe n°2 on Ebay. Now i'm looking for a used battery ECU.
    Onece I receive both and install it everything should go better. Really hope !
    At the same time the legal procedure to find an amicable solution with the dealership is initiated. If no answers, it will go further.
    SFO likes this.
  15. Pyho
    Pyho Junior Member
    31
    Bordeaux, France
    II bought a used battery ECU today. But working.
    Still waiting the Wire Frame n°2 ordered in japan.
    I'll post some news at the end of november to tell you if everything is right again !
    SFO likes this.
  16. PriusCamper
    12,058
    4,893
    Looks like a good one! The only failure I've ever seen in these, which is very common in parts of the world with lots of winter humidity, is the pins on the right side of that orange plug socket get heavily corroded to the point of disintegration which leads sparks and eventual frying out of where those pins connect to the circuit board. Seen it in both Gen2 and Gen3 and if you go to a Toyota Stealership with this problem they'll tell you $4K ($800 for new ECU and $2K for new battery + labor). Saddest part is many people get rid of their Prius because of the cost of this repair when in some cases an hour of labor is all it takes to clean those pins if the damage isn't severe. And if it is severe it's roughly $50 for a used ECU and $50 For the wire harness that plugs into the ECU.
  17. Pyho
    Pyho Junior Member
    31
    Bordeaux, France
    @PriusCamper you're so right
    For information, here are pictures of my ECU and the Wire Frame of the battery pack before I cleaned them in August. I think changing them is the best option because it had a lot of corrosion.
  18. Pyho
    Pyho Junior Member
    31
    Bordeaux, France
    Hi
    Some news today I changed the WireFrame A and the battery ECU.
    I did a test run of the Prius and it droves fine for 15 miles. No error code, no lights at the dashboard.
    Then suddenly red trangle came up again with the red logo of the car on the display screen. My HV battery suddenly dropped from 6 bars to 3 bars and engine stayed alaways on.
    I went back home and tested with Torque Pro.
    Errors are P0A90 and P0AC0.
    Exactly the same I had the first time. And since then my inverter has been replaced by Toyota and I changed battery ECU and WireFrame 2.
    I'm quite lost :/
  19. PriusCamper
    12,058
    4,893
    Dang!!! Wish this had been fixed with ECU and Wire Frame... I've seen that P0A90 codes when there were bad electrical connections in the pack even though that error code doesn't point to that. To be clear, these are the symptoms if you have that error code for real:
    Also, did you by chance open up your replacement ECU to see if everything was clean inside and no damage of corrosion or shorted out stuff?
  20. Pyho
    Pyho Junior Member
    31
    Bordeaux, France
    Yes when error showed up I lost acceleration. No more power under right foot. I had to restart the car to have power.
    I'm wondering if the problem since the beginning isn't something with the transaxle.
    To be sure I also re-checked the coolant of the inverter and my 12v battery -> all fine.
    I'll check the inside of the battery ECU tommorow. And check the connections of the hybrid ECU in the dashboard too.
    Although i'm wondering why the problem shows after 15 miles and not since the start of the car. Looks like something heat and the make an error... or something like that.
    EDIT : Next week I'll buy a new 12v battery just to be absolutely sure that the problem doesn't come from here. I found a brand new Varta A15 for 48€.
    #20 Pyho, Nov 21, 2020
