Long Term Question - Smooth Ride
Discussion in 'Gen 2 Prius Main Forum' started by johnny51981, May 6, 2007.
  1. johnny51981
    johnny51981 New Member
    42
    Kent, WA
    I've had my Touring Pkg 6 for a week now, and the ride is SOOOO smooth. It's like butta.
    I remember my Blazer was a smooth ride when I first got it, but that eventually went away.
    I've always been "American Made" when it comes to my cars, so after finally popping my foreign cherry, I wanted to know if, like the Chevy, does the smooth ride in the Prius eventually diminish?
  2. SW03ES
    SW03ES Senior Member
    2,480
    176
    Gaithersburg, MD
    Our Prius is 3 years old, still rides as good as it did before. (the Prius does ride well, lots of road noise but it rides well). In my experience with Toyota and Lexus cars, they keep their composure with age FAR better than American cars, especially SUVs. I had an Explorer (A Limited, it was a nice, $40k Explorer) before I got the Lexus and by 70k miles you could definately tell it was getting old, rougher ride, rattles, the drivetrain was nowhere near as smooth as it used to be. Not the case with a Toyota.
  3. johnny51981
    42
    Kent, WA
    <div class='quotetop'>QUOTE(SW03ES @ May 6 2007, 11:07 AM) [snapback]436431[/snapback]</div>
    Thanks! That is when I noticed my Blazer was starting to get a lot of noise...so I had to turn up the radio. :lol:
    I'm on my 3rd brand spanking new car in my lifetime..and I never put many miles on them. I had a 2000 Chevy Cavalier, got it with 9 miles on it and traded it in in 2002 with just over 10K. Got my 2002 Blazer, got it with 14 miles on it and just traded it in last week with just over 51K on it. So that tells you how much I actually drive. LOL
  4. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    Get those tires up to where they should be, and your ride will become
    refreshingly harsher [although not by much]. This will be amply
    compensated for by the MPG average and much slower tire wear.
    _H*
  5. johnny51981
    42
    Kent, WA
    <div class='quotetop'>QUOTE(hobbit @ May 6 2007, 11:21 AM) [snapback]436434[/snapback]</div>
    Pardon my ignorance, but can you explain what you mean by this?
  6. SW03ES
    2,480
    176
    Gaithersburg, MD
    Some people on this board inflate their tires to higher than the PSI reccomended by Toyota to increase their MPG. Personally I'd rather have a more comfortable ride even at the expense of a couple MPG.
  7. NoMoShocks
    NoMoShocks Electrical Engineer
    1,292
    82
    Camas, WA
    <div class='quotetop'>QUOTE(johnny51981 @ May 6 2007, 11:28 AM) [snapback]436439[/snapback]</div>
    Johnny is talking about using tire pressure of of 42 psi in your front tires and 40 psi in your rear tires. That will help your gass milage and reduce wear on the outer edges of your tires without effecting the smooth ride very much. Be sure to check this pressure while the tires are cold, not after you have been driving for a long time. Buy your own tire presure guage and use the same on every time, becuase each fueling station may have guages that are slightly off.
    The dealer most likely used Toyota's recommended tire pressure of somewhere around 30 psi.
  8. ystasino
    ystasino Active Member
    793
    50
    Tucson, Arizona
    <div class='quotetop'>QUOTE(NoMoShocks @ May 6 2007, 02:56 PM) [snapback]436447[/snapback]</div>
    I moved from the dealer 35/33 to 46/44 and the ride is definitely much bumpier. In addition to the +2 mpg, from the experience of others here, I expect the tires to last a 6-12 months longer.
