Longer Charging Cable?
Discussion in 'Prime Main Forum (2017-2022)' started by Gianni I, Dec 27, 2017.
  1. Gianni I
    Gianni I Member
    58
    35
    Long Island
    So I am picking up my Prius Prime after work today. I see some of the charging cables are around 25ft.
    Are there any longer cables available? I would probably need around 35-40 feet for me to be able to keep my car in the street (if my wife is parked in our driveway) and still be able to charge.
    I saw some comments about extension cords. My father in law has a ton of electrical knowledge from his job so I can make a heavy duty (10 gauge) extension cord if needed, but if I do that, does that mean that little box that is next to the plug will be outside? Can that go outside or that needs to stay inside. Looking for a solution and haven't found anything concrete in my searches thus far.
    Thanks!
  2. Mark McIntyre
    Mark McIntyre Member
    36
    51
    Boulder CO
    I have had my Prime since July of 2017. I am using a 12 gauge extension cord from my garage to outside. The charging cable dongle (technical term for the box thingy)is outside and is rated for outdoor usage. Mine sits in modest amounts of snow and water etc...
    priuscatprimeguy likes this.
  3. Gianni I
    Gianni I Member
    58
    35
    Long Island
    Thanks for one your reply! Good news!
  4. Dudley1030
    Dudley1030 Active Member
    200
    139
    Lawrence, KS
    I had a 12 gauge 25' ext cord I used for a welder. I used that for the prime until I installed a 220v in the garage. It's nice because I can also use the 220 v for my welder! If you use to small of an ext cord, it can overheat and start a fire.
    Andyprius1 likes this.
  5. Gianni I
    Gianni I Member
    58
    35
    Long Island
    I would 100% use a heavy gauge extension cord. I'm a stickler for that kind of stuff and will make sure to go above and beyond to keep it safe.
    My main worry was having the dongle sitting outside exposed to the elements (heat/snow/rain/etc..) Mark seems to have never had a problem with that which is good news.
  6. CraigM
    CraigM Active Member
    208
    208
    Portland, Oregon
    If your set-up crosses a sidewalk, be sure it’s not a tripping hazard.
    Andyprius1 and Prodigyplace like this.
  7. Gianni I
    Gianni I Member
    58
    35
    Long Island
    Thanks for the heads up, but it doesn't cross a sidewalk.
  8. Dudley1030
    200
    139
    Lawrence, KS
    I think he was meaning looking down for the cord not heads up. LOL, sorry couldn't resist.
  9. Dudley1030
    200
    139
    Lawrence, KS
    I too was wondering. The documentation says it's waterproof. I hope so!
  10. bisco
    49,511
    have charged my pip outside in all kind of weather and 12 ga extension cord, no problems.
  11. padroo
    padroo Senior Member
    2,763
    2,250
    Just because it works doesn't mean it is right. You should be following the electrical codes in your area.
    Dudley1030 likes this.
  12. Dudley1030
    200
    139
    Lawrence, KS
    Not sure if you were addressing my post or one of the others. But, I made sure my install surpasses our local codes, even though the electrician said it was over kill. It also has a GFCI on the 220 since it is in a garage. Better safe than sorry.
  13. PT Guy
    PT Guy Senior Member
    1,085
    710
    Washington, the state
    There are rain proof extension cord connector covers.
    rcaine and Dudley1030 like this.
  14. padroo
    2,763
    2,250
    I was just putting my two cents in for safety.
    Electricity is still nothing to play with. I spent most of my life in heavy industry around high voltage.
    #14 padroo, Dec 28, 2017
  15. bisco
    49,511
    fortunately, we're only talking 120 volts, but still, nothing to fool around with.
  16. bisco
    49,511
    we don't really have electric codes for extension cords. i'm sure there must be a table for amperage, lent and gauge though.
  17. padroo
    2,763
    2,250
    jdembones and Dudley1030 like this.
  18. bisco
    49,511
    thank you, i believe the evse has current data available in the o/m. interesting that they show 16 ga for 25' at 1-13 amps, i think that has us covered.
    one concern is that the plugs usually heat up faster than the cord.
  19. Old Bear
    Old Bear Senior Member
    712
    1,049
    Boston, Massachusetts USA
    There are two issues with extension cords (or any wiring, for that fact): 1) voltage drop; and, 2) heat dissipation. They are related in that the smaller the wire size (which means higher the gauge number), the higher the resistance per foot and the more power will be wasted heating up the cord. If the wire size is small enough, there can be enough heat to melt the cord's insulation or even cause a fire.
    If the wire size is small -- or the cord is long -- the voltage drop may be extreme enough to prevent your car from charging. The charging device which comes with your car wants to see about 120 volts. If the voltage is too low because of the resistance encountered in an undersized cord, you likely will have a problem.
    Outdoors, you need to add a third consideration: weather protector of the connectors. PTguy posted a photo of one kind of protector which you can use. But it is intended to be weather-proof, not water-proof -- so you don't want it submerged in a puddle.
    Ground fault protection has been discussed in this forum many times. The charging device which comes with your Prime will provide ground fault protection where you connect it to your car, but it will not provide protection where it is plugged into the wall or into an extension cord. You need to have a ground fault circuit interrupter ("GFCI") installed at the outlet where the cord is connected to your house wiring or, alternately, a GFCI circuit breaker at your electrical distribution panel.
    Keep in mind that to maintain the same voltage drop, longer extension cords must have bigger diameter wires than shorter cords. As I noted above, wire sizes get smaller as the gauge number gets bigger. For example, a cord with #10 wires offers much less voltage drop than a cord with #14 wires.
    And, if you're going to lay the cord anywhere where someone might trip, get an orange traffic cone or something to warn people.
  20. Gianni I
    Gianni I Member
    58
    35
    Long Island
    In my case since I'm the one that started the topic here is my scenario.
    The charging cable that comes standard with the prius is about 16-20ft. Did a super quick measurement on that so may be a little off. Anyway I need to get to around 35feet (40 the most) for me to have my car parked on the street and my wife in the driveway. I live in a private community so there is no sidewalks, no walking traffic so don't need to worry about tripping hazards etc..
    Noted on all the facts on the extension cords, heat/voltage etc. With a homemade 10awg exension cord with proper 20amp connectors and a length of about 5-10 feet, I don't think there will be an issue. It also isn't going to be a permanent solution. Just for the times that my wifes car will be in the driveway. For intermittent usage knowing I will have a strong enough cable I think it will be OK.
    I think the blanket statements about not using extension cords is made b/c they know people will use insufficent cords. If you have the knowledge behind what's being used I don't think it's a problem.
    benagi and bisco like this.
