Look my car did today...
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Gas Mizer, Jun 16, 2014.
  1. Gas Mizer
    Gas Mizer Member
    153
    49
    Redding, California
    2018 Prius
    I was driving around 20 mph about 3 minutes after starting the car when...
    SCH-I605 ?
    51,141
    some guys have all the luck...
  3. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    You are still under warranty, right ?
    Take it in. Something is wrong.
  4. going red baby!
    going red baby! still a n00b
    610
    96
    Los Angeles
    Wow! So what happened when that came on? Were you able to keep driving?
    I don't know why I'm so surprised, I don't even know what that means!
  5. Mendel Leisk
    40,574
    I puzzled over the OP's posted pic, then went away. Taking another kick at the can: yes what the heck does it mean?
  6. retired4999
    2,652
    625
    Eau Claire, Wi.
    Is that a carista obII reader print out? If so I do not know what that means. Check with carista?
  7. IMkenNY
    IMkenNY Im just being nosy
    477
    303
    Tropical Buffalo NY
    Four Touring
    That error was most likely caused by your ELM327 Bluetooth module upsetting the can bus , remove it and restart your Prius and you should be fine.
    You may want to try a different ELM327 adapter.
    Or you may want to keep it in if you dislike ABS :)
    Gas Mizer and PriusInParadise like this.
  8. bisco
    51,141
    op went away too...
  9. Gas Mizer
    Gas Mizer Member
    153
    49
    Redding, California
    2018 Prius
    Sorry, my new job prevents me from being able to the check the forums during the week. It appears it had something to do with leaving my OBDII bluetooth adaptor plugged in. I unplugged it, shut the car off, turned it back on and it went away. As for what it did to the car... While those lights were on, the vehicle ran fine, but would not recharge under braking, and the braking was HORRIBLE! So I'm assuming it did something with the KERS system. But, all is well now. I just don't leave the adaptor plugged in.
  10. Easy Rider
    982
    210
    N. Central Florida
    Owners of other cars with the CAN bus have had similar (or other wierd) problems.
    Best to NOT leave the scan tool plugged in all the time.
  11. Todor
    Todor Junior Member
    85
    23
    2013 Chevy Volt
    Yeah, I recommend NOT leaving ELM327 devices plugged in. Just plug it in when you need it and unplug it afterwards. I don't know if it can really cause such errors when it's not being used, but I guess anything is possible, esp. with Chinese devices.
    But yeah, the error means that the communication between the ABS module and something else was interrupted. And since this communication is critical for the ABS system, it just gives up and turns itself off (and from your description, it sounds like this also turn off regenerative braking).
    Just out of curiosity, were you doing anything with Carista when it happened?
