Looking @ 2007 with higher mileage
Discussion in 'Gen 2 Prius Main Forum' started by kristen, Oct 3, 2012.
  1. kristen
    kristen New Member
    Hi everyone,
    I've been eyeing a 2007 Prius to replace my failing 1999 Saturn. The price is right considering the mileage but it has 135,000 miles. It had one owner-a livery company. Carfax shows it's had regular maintenance & only issue was a failed emissions test in 2011, but I believe it has a current sticker so must have passed since then. If not they said they will not sell it unless it will pass.
    I commute 50 miles a day. I'd be making payments for 3.5 yrs.
    considering its mileage am I being foolish or is it truly very feasible I can get upwards of 200k if I continue regular maintenance?
    Thanks for any advice.
    Kristen
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    What state are you in? If you're in CA or a CARB state (and the vehicle was purchased, operated and registered there), IIRC, the emissions warranty should be 15 years/150K miles. If not, it's MUCH shorter.
    Re: the emissions test, heh. Heck, in CA, AFAIK, hybrids are exempt from our smog test, for now. :) (Hybrid-Electric Vehicles Exempted From Initial Smog Check) I know I didn't need to have it done when I brought my Prius back to CA from WA. My car was originally bought in CA but I had to move to WA for work....
    I'd previously brought back non-hybrid cars from WA to CA and had to get them smog tested in CA before I could register them in CA.
    kristen likes this.
  3. Fubar1764
    Fubar1764 Member
    127
    Houston, TX
    The age of the battery matters more than the mileage. Most engines are grenade-proof, particularly Toyota and Honda motors. I'd be concerned about the transmission - was the fluid changed regularly, that sort of thing. If properly maintained, expect the transmission to last another 100k.
    As with all things older and worn, expect maintenance and repair/replacement. If you live in an area that requires a/c, assume the a/c was running every mile the car was running, which also means the a/c components are more likely to require repair.
    Winter is a good time to buy a Prius. If you hold off your purchase, the sales price may come down. ;)
    kristen likes this.
  4. kristen
    kristen New Member
    I'm in MA. Are repairs for the Prius more expensive? Is it harder to find a mechanic?
  5. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    MA is a CARB emissions state. I don't know what year it started though.
    You might want to check the warranty booklet to see if it mentions MA under the 10 year (120 month)/150K mile HV battery warranty. If yes, you should consider vehicles that were purchased, registered and operated in MA or other CARB states to get the benefit of that longer warranty.
  6. PriusGuy32
    1,417
    512
    Harrison Township, Michigan
  7. usnavystgc
    3,159
    989
    Tucson, AZ
    4 sure. That one even has bluetooth.
  8. PriusGuy32
    1,417
    512
    Its about 15 minutes away from me if you want me to check it out for you :D
    I dont know where the OP lives, but dont be askin' me to drive no car cross country for ya...lol
  9. usnavystgc
    3,159
    989
    Tucson, AZ
    I hear ya. I'm very happy with my 06 but that is a seriously good deal.
  10. kristen
    kristen New Member
    That would be a bit too far away for me! :)
    The one I've been looking at seems to have most of the cool extras like bluetooth, 5 disc changer, etc.
    It's priced at $9,995, but the did drop it. We ran the 12 v battery test and that will need replacing so gonna run that by them too. It also needs an alignment and the tires checked as that yellow icon was lit up. Tire wear is ok..should last another 12-18 months, but I have a 50 mile daily commute so perhaps a bit sooner.
  11. PriusGuy32
    1,417
    512
    Kristen, where do you live?
  12. kristen
    kristen New Member
    Boston area.
  13. jdenenberg
    jdenenberg EE Professor
    3,857
    1,857
    Trumbull, CT
    2020 Prius
    LE AWD-e
    A Prius likes a long commute and will thrive in that usage. The Livery company also used it for long drives, so it will not have had the harder life that urban driving would cause. My 2004 Prius has given me great service in mostly highway driving.
    There are independent hybrid repair shops in the Boston area:
    Preferred Independent Hybrid Car Repair and Service Shops | Hybrid Cars
    But you will need to do your research to get reviews of their service.
    JeffD
    kristen likes this.
  14. dorunron
    dorunron Senior Member
    3,318
    1,103
    Houston, TX
    I do agree that the Prius likes long commutes. If you drive the Prius 50 miles instead of 15, your MPG will probably be higher in the long run unless you are driving at very fast highway speeds. When I say very fast, I am referring to above 70 MPH. If you are driving around town and keep your speed in the 35 area and drive that 50 miles, your mileage will be excellent if you utilize "pulse and glide". When I say excellent, I am stating that the mileage should be well above the EPA estimate which is 48 City for the Gen 2 Prius. If you just drive the car like any other car, your mileage will probably be around 45 to 48. Remember YMMV.
    Don't be afraid of the Prius. It is a good car, just remember to keep it maintained and it should last a long time. I am not saying you won't have to repair it from time to time. All cars have to be repaired occasionally.
    Good luck to you Kristen and welcome to Prius Chat.
    Ron
    kristen and PriusGuy32 like this.
  15. Erik Aalto
    Erik Aalto Junior Member
    47
    North Carolina
    Came into talk about the long commutes and gas mileage.
    My Prius was built in 09/07, and currently sits at 129,200 miles. I drive it on back country roads to work, and avoid highways if possible. When on the highway, I tend to cruise at 66 MPH. MPG today was 55.2. It has been the single most reliable car I have ever owned, and I loved it so much that I bought another one.
  16. The Critic
    The Critic Resident Critic
    3,193
    2,322
    CA
    I would say pass. The exposure is simply too high at that mileage, especially since fleets are not always great about basic maintenance.
    At best, you only have about 15k of battery warranty left.
    iPhone ?
