Looking for 12V+ Power Lead Under the Hood
Discussion in 'Gen 3 Prius Accessories and Modifications' started by MPSchenck, Sep 25, 2015.
  1. MPSchenck
    MPSchenck Member
    46
    62
    Cleveland, TN
    Ok, so I have never installed an HID kit before, but I have just ordered the Morimoto Elite HID System kit form The Retrofit Source.
    I have 2 questions for those that might know.
    1) I included the "optional" Anti-Flicker Capacitor Link, but I'm not sure if I will actually need it? It was $15 so if I end up not needing it there is no great loss.
    2) The instructions for the kit include a few step that makes me pretty nervous. Mostly because of all the HID install videos I've watched on Youtube, none have included these steps as far as I can tell.
    Screen Shot 2015-09-25 at 1.46.25 PM.png Screen Shot 2015-09-25 at 1.46.37 PM.png
    Where's the 12V+ power lead under the hood?
    Any help in this dept would be greatly appreciated.
  2. JimboPalmer
    12,470
    6,863
    Greenwood MS USA
  3. MPSchenck
    MPSchenck Member
    46
    62
    Cleveland, TN
    Nice! Thank you
    iPhone 6+ ?
  4. xliderider
    xliderider Senior Member
    7,872
    3,116
    Honolulu, HI
    Here's a picture of my engine fuse box. There is a bolt exposed under the cover (with the screwdriver near it) by the heavy gauge white wire in the top center of the picture. You can treat that bolt like the positive terminal of your 12v auxillary battery (always hot).
    Or, you can use one of the two open 1/4" push on terminals at the back of the fuse box, Which are much easier to access than the bolt mentioned above. In this pic they are the ones with the heavy gauge red wires connected to them. I have my highbeam DRLs and Foglights running off these terminals.
    Dylan Doxey likes this.
  5. MPSchenck
    MPSchenck Member
    46
    62
    Cleveland, TN
    Screen Shot 2015-09-25 at 3.36.59 PM.png This one?
    To use those push on terminals I would have to cut the washer like connectors off and replace with the push ons? I assume I could get the push on things at, say, AutoZone/Advanced/O'Reilly's?
  6. xliderider
    7,872
    3,116
    Honolulu, HI
    I can't see your pic on my smartphone. But yes, any autoparts store, or even Walmart automotive section. Just get 1/4 inch push on type crimp on connector for the appropriate wire gauge size. Maybe some heat shrink tubing to put over the connector as well.
  7. MPSchenck
    MPSchenck Member
    46
    62
    Cleveland, TN
    Cool, I can do that.
    Anybody know if I actually need that bit? I guess it couldn't hurt to install it either way.
  8. xliderider
    7,872
    3,116
    Honolulu, HI
    Yeah, you can put ring terminals under that bolt. Disconnect the 12v auxiliary battery before touching that bolt though.
  9. StarCaller
    StarCaller Senior Member
    1,246
    697
    Cedar Crest, NM, USA
    not needed/
    I installed mine just with the harness/
    works perfect//
  10. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    778
    514
    Outside Philly, PA
    If you use those push-on connections in the fuse box for an accessory, should you include an in-line fuse (since I gather you are connecting directly into a main)?
  11. xliderider
    7,872
    3,116
    Honolulu, HI
    Yes, definitely.
  12. MPSchenck
    MPSchenck Member
    46
    62
    Cleveland, TN
    Yes, if you use the included HD Relay harness there is an inline fuse.
    iPhone 6+ ?
  13. blake9809
    blake9809 Junior Member
    27
    Minneapolis, Minnesota
    2002 Prius
    SE
    hey any update on where you got the 12v positive lead connected to? photos would be excellent. I came across this post and i am also installing a HID kit in my 2002 prius. I have the capacitors and also the wiring harness that is asking for 12v positive lead. I dont think you have to use the wiring harness but its recommended so if i can find a 12v power source under the hood i would like to use it. Let me know how your turned out. thanks
  14. Mendel Leisk
    38,736
    This shows the main 12 volt lead at the fuse box:
    Mr. F likes this.
  15. blake9809
    27
    2002 Prius
    SE
    I ended up using one of these add-a-circuit fuse tap to get power from a fuse under the hood for the HID harness. Works great, thought i would share.
    Montgomery and jzchen like this.
  16. Wums
    Wums New Member
    Missouri
    so im just doing some upgrades to my prius, where do you install the bulbs? next to the main ones there or are these like low riders?
