Looking for 2006 TPMS Wiring Diagram
Discussion in 'Gen 2 Prius Technical Discussion' started by ydpplqbd, May 24, 2021.
  1. ydpplqbd
    ydpplqbd Active Member
    551
    253
    I am looking for a 2006 TPMS wiring diagram. Can anyone point me in the right direction?
    Thanks in advance.
  2. PhilWray2
    PhilWray2 Junior Member
    Malaysia
    ----UK----
    How's this?
    ydpplqbd likes this.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,803
    2017 Prius c
    Not sure what you are asking because the transmitters in each wheel/tire are wireless so there is no "wiring".
    There is, of course, a receiver somewhere. Is that what you are trying to find ?
  4. ydpplqbd
    551
    253
    Clearly, I did a poor job in my original post communicating what type of wiring diagram I am looking for. I will try again as follows:
    I understand that the Gen2 Prius has a separate ECU for the TPMS and that such TPMS ECU is powered by a fuse in the fuse box. Based on some reading, removal of the fuse powering the TPMS ECU will shut off the TPMS warning light. But, removal of the fuse powering the TPMS ECU will cause a new dash light to illuminate (apparently, this new dash lamp warns that the TPMS system is inoperative).
    Rephrased queries: I am looking for a 2006 TPMS wiring diagram for the TPMS ECU and conductors feeding into the TPMS ECU [portion of this revised question has been underlined for emphasis and clarity].
    Can anyone point me in the right direction in order to obtain such a wiring diagram and determine the Gen2 location for the TPMS ECU [this addition to the second, original question has also been underlined for emphasis and clarity]?
    #4 ydpplqbd, May 25, 2021
  5. Elektroingenieur
    2,515
    3,284
    Three Touring
    See the Electrical Wiring Diagram (more info) for 2006 Prius cars, Toyota publication number EM01R0U.
    In the book version, in the System Circuit section, see pages 294–297 (Tire Pressure Warning System); in the Relay Locations section, page 20 (Instrument Panel); in the Electrical Wiring Routing section, page 51 (Position of Parts in Instrument Panel), and in the Connector List section, page 385 (connector T11).
  6. ydpplqbd
    551
    253
    Many thanks!!!!!!
    Elektroingenieur likes this.
  7. wjtracy
    wjtracy Senior Member
    11,368
    3,608
    Northern VA (NoVA)
    If the objective is to turn off TPMS system and warning light, to my knowledge, nobody has found away to do this on Gen2. Gen3 there is a way (jumper hack).
    One Prius Chat member figured out how to reprogram the ECU for 5 tires, I do not know if it could be programed to remove tires.
    I showed a way to use a dummy TPMS reading, using a binder clip to create artificial pressure on a TPMS unit not on a tire..
  8. ydpplqbd
    551
    253
    My initial objective is to turn off the Tire Pressure Warning light on the combination meter. Second objective is to replace Toyota sensors (315MHz) with the following: aftermarket system with internal 433MHz sensors and dash screen/indicator with actual tire pressure for each tire. Third objective is to join aftermarket system alarm to the Gen2 Prius' Tire Pressure Warning light. IOW, the Gen2 Prius' Tire Pressure Warning light illuminates when the aftermarket system sounds its alarm.
    I have already purchased and returned one cheap Chinese TPMS system with internal sensors. Reasons for return are as follows: i.) head unit would not pair with sensors (this problem maybe attributable to TPMS instructions created using Google translate); ii.) no vendor support; and iii.) head unit was of low quality and control button failed after about 1/2 hour of testing. Two more internal sensor aftermarket 433MHz units have been ordered and should be arriving today. I will test these units for QC, pairing and ease of use on the desktop before installing.
    wjtracy likes this.
  9. ydpplqbd
    551
    253
    Right now I am trying to understand how the Gen2 TPMS System works. My understanding is that the Gen2 TPMS System is composed of the following components: i.) wireless 315MHZ wheel sensors (current Toyota P/N: 42607-33012); ii.) Tire Pressure Warning Antenna and Receiver (Toyota P/N: 89769-47010 obtained from used items for sale on ebay); iii.) Tire Pressure Warning ECU; iv.) Tire Pressure Warning Reset Switch; and v.) wiring harness connecting items "ii", "iii" and "iv" together with the combination meter.
    Tire Pressure Warning Antenna and Receiver ("TPWAR") has three wires/conductors emanating from it (which in turn are connected to the Tire Pressure Warning ECU). Wires are described as follows in the wiring diagram:
    R (Red) +5V
    G (Green) Gnd
    B (Black) RDA
    I am uncertain what the acronym "RDA" stands for (any help on this definition would be appreciated). However, it appears to me that the TPWAR's RDA (the black wire) is likely an ouput to Tire Pressure Warning ECU and such output likely varies between 0V and 5V. Apparently, this RDA ouput is dependent on the TPWAR's analysis of the wireless 315MHZ wheel sensors. If anyone can critique my analysis it would be greatly appreciated.
    #9 ydpplqbd, May 26, 2021
  10. ydpplqbd
    551
    253
    Here are some pics of the TPMS system from the wiring diagram:
  11. ydpplqbd
    551
    253
  12. ydpplqbd
    551
    253
    Many thanks on the attachment. Somehow I missed your post when first posted. My apologies. Your attachment is very helpful for many issues (including locations of TPMS ECU and Tire Pressure Warning Antenna and Receiver).
    Thanks again.
    PhilWray2 likes this.
