Looking for a jump pack
Discussion in 'Gen 5 Prius Main Forum' started by HamiltonPrius, Jan 1, 2026 at 11:41 AM.
  1. HamiltonPrius
    HamiltonPrius Member
    184
    88
    Parts unknown
    2026 Prius
    Reading some of the dead battery posts has me thinking about buying a jump pack even though I have never had battery problems with my 2 Prius’s.
    I’m looking for a small portable jump pack with longer cables. I have found all kinds of jump packs but they have short cables, the jump packs I have found with longer cables aren’t small.
    A tire compressor, jump pack combo would be even better
    Better safe than sorry!
    Any suggestions would be appreciated.
    #1 HamiltonPrius, Jan 1, 2026 at 11:41 AM
  2. BiomedO1
    BiomedO1 Senior Member
    3,718
    1,927
    SacTown, Ca
    Don't know how handy you are but if you have a DVM, you can just make a 24 inch extension ground wire.
    1. set your DVM for volts DC and connect it to your under hood jump point.
    2. start touching bolts in the area, your looking for a solid 12VDC - that's a good ground point.
    3. crimp a solder-less eyes that will fit that bolt on both ends. 24 inch 00 wire should do it, preferably black insulation.
    4. remove bolt and install one side of wire. When finished retest for 12V on the other end of the wire.
    5. That will be your ground clamp point for your jump pack. Just wrap it up and tuck it somewhere until needed.
    Like the boy scout model; always be prepared.
    DnxnIaIfy Jump Starter,8000A Portable Car Battery Jump Starter with Air Compressor,60000MAH Battery Jump Box Car Starter,12VBattery Booster Pack with 150PSI Digital Tire Inflator - Walmart.com
    I just found this on a quick search - NOT really recommending it - I've got two big old ones with handles that I've replaced the large battery within each of them. That's how old they are, but they still work. I just toss one of them in my trunk on road trips - around town there's friends, ride share, and AAA.
    Hope this helps....
    PS; the 2026 Prius doesn't contain ANY flat tire recovery system - other than that slime kit. NO tools, jack, or tire iron. Depending on your skill level, you may want to preplan for that emergency - since these newer LLR tires are much thinner than 'normal' tires that take more of a beating. Got more flats combined on my 21 Prime than all other cars I've driven in the past 40 years. Took a small mpg hit and replace them with real tires around 30K miles. Pulled another nail out on my last rotation that didn't penetrate my new shoes.;)
    #2 BiomedO1, Jan 1, 2026 at 1:03 PM
    52,030
    i did the same thing. bought a jump pack and thinking about compressor. make sure you get one with a dead battery override
    BiomedO1 likes this.
  4. BiomedO1
    3,718
    1,927
    SacTown, Ca
    Yep, there's usually instructions on how to over-ride the battery safety checks to shunt power to your system on a fully dead battery - BUT who reads instruction, that's for nerds not the kool kids.:(:oops:o_O
    My stuff is so old - there's NO safety checks, not stupid proof.:whistle: BUT they WORK. I may FRY something in the process if I hadn't had my morning coffee.:(
  5. HamiltonPrius
    184
    88
    Parts unknown
    2026 Prius
    Thanks for the thoughts but any product suggestions? I would rather not modify anything under the hood. Do they even make a portable jump pack with longer cables?
  6. bisco
    52,030
    why longer cables? i have a noco with short cables. once you've uncovered the battery or jump point, it doesn't matter. (to me)
    #6 bisco, Jan 1, 2026 at 2:06 PM
  7. bisco
    52,030
    i wonder if this has the same connector as the noco jump cable?noco-gc004
    and how much juice you would lose through it.
  8. HamiltonPrius
    184
    88
    Parts unknown
    2026 Prius
    Because for a 2026 model the positive terminal in the fuse box and the preferred manufacturer ground lug are too far apart for regular cables to reach.
  9. bisco
    52,030
    i'm not sure the preferred ground is important
  10. HamiltonPrius
    184
    88
    Parts unknown
    2026 Prius
    Maybe not, I’m willing to entertain other ground sites.
  11. bisco
    52,030
    i just check all the bare metal with a volt meter
  12. Paul Gregory
    Paul Gregory Senior Member
    2,170
    575
    Alberta
    2024 Prius Prime
    XSE
    I bought myself a Dewalt jump pack, and replaced the alligator clips with 12V male plug. This way, I can jump my battery from the driver's seat without having to go under the hood. I wired in a live 12V socket, which is necessary for this to work.
  13. HamiltonPrius
    184
    88
    Parts unknown
    2026 Prius
    Wait a minute…..just thought about this a little further. How can I check continuity between a bare metal piece under the hood to the battery negative when the battery is in the trunk?
    #13 HamiltonPrius, Jan 1, 2026 at 4:40 PM
  14. BiomedO1
    3,718
    1,927
    SacTown, Ca
  15. bisco
    52,030
    the battery is grounded to the body. most of the car is part of that. any bare metal under the hood will get back to the 12v negative post.
    you can check it by putting a volt meter on the jump post, and any metal close enough for the jump pack clips to connect to.
  16. BiomedO1
    3,718
    1,927
    SacTown, Ca
    Yep; re-read my post #2. Positive probe on the jump point; negative probe on the suspected ground point. Your NOT looking for continuity, your looking to complete the circuit and get a 12VDC reading or whatever your current battery reading is.
