Looking for battery help in the Palmdale Ca
Discussion in 'Generation 1 Prius Discussion' started by JamesGilmore, Feb 25, 2020.
  1. JamesGilmore
    JamesGilmore Junior Member
    palmdale ca
    2002 Prius
    I
    I have a 2002 prius and been getting repeated p3006 codes on my 2002 prius. wonder what the best battery option is and from where ?
  2. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
  3. JamesGilmore
    palmdale ca
    2002 Prius
    I
    where are you I been getting p3006 codes so I am thinking there is or are bad cells. but befor I replace the battery would like to know if there is something else that can cause p3006. do not want to drop a battery in and find out it s something else...
  4. jakilo
    jakilo New Member
    roma
    PALMDALE California US has battery reusing areas close by where you can reuse practically all vehicle batteries. You should simply drop off the battery and they'll wrap up. Truth be told, most retailers will give you an acknowledgment for your pre-owned battery regardless of whether you don't buy another battery.
  5. Nelsonprius
    Nelsonprius Junior Member
    72
    Nelson, BC Canada
    2001 Prius
    I
