Looking for coilovers with camber plates
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Nobody123, Apr 21, 2015.
  1. Nobody123
    Nobody123 Member
    160
    33
    United States
    2015 Prius Plug-in
    I'm shopping for a set of coilovers for my PiP that has integrated camber plates (at least for the front). So far the only one I've found is the HKS.
    Could anyone else recommend an alternative? Thank you.
  2. Nobody123
    Nobody123 Member
    160
    33
    United States
    2015 Prius Plug-in
  3. bino
    bino JDM ZVW30
    1,348
    706
    SoCal 91739
    I believe Tein Flex series and the RSR Black series would have camber plates.... (but not 100% sure)....
    but my vote would be to get the HKS ;)
  4. ncases
    ncases Senior Member
    609
    672
    Chicago
    Hi Bino. Can we order HKS here inthe states or only in Japan? Im interested with the HKS as well I like the drop height.
  5. Xterra72
    Xterra72 Senior Member
    1,404
    1,658
    HKS! Haven't heard that brand for a looong time! Had HKS mushroom air filter and HKS Cat Back Exhaust system on my Honda Civic 4 door back in the 90s.(y)
    That's an OG Brand for compact sports car back then. :D
    #5 Xterra72, Apr 25, 2015
  6. bino
    bino JDM ZVW30
    1,348
    706
    SoCal 91739
    ncases likes this.
  7. Nobody123
    Nobody123 Member
    160
    33
    United States
    2015 Prius Plug-in
    Thanks for the feedback.
    Right now I'm more concerned with the difficulty of adjusting camber plates on the Prius. There is really very little clearance between the top of the strut tower and the cowl.
    I need to talk to the alignment shop and get their input before I decide. I asked them before in theory about camber plates vs. camber bolts and they're indifferent and can accommodate either.
    I'll have them look at the car again and get a response. If both are equal then I would go with the camber bolts for easy adjustment.
  8. bino
    bino JDM ZVW30
    1,348
    706
    SoCal 91739
    how much camber do you need....? if it's just about -2 the camber bolts would do....
  9. SubCode
    SubCode Senior Member
    731
    1,338
    Just wanted to know is there an installation video or pics on how to get to the front struts...I wanted to do the install myself but my you tube trolling cannot find a how to?
  10. Nobody123
    Nobody123 Member
    160
    33
    United States
    2015 Prius Plug-in
    I'm getting the car corner-balanced and the shop will suggest a camber setting. The problem is not how much camber I need, but it's because I don't like the idea of eccentric bolts having smaller diameter = weaker.
    I usually prefer camber plates because of not having to compromise strength with eccentric bolts, and it's easier to adjust camber on top of the car rather than turning the eccentric bolts from the bottom.
    With this car though, I'll have to see how easier it to adjust camber plates. I may not have a choice.
  11. Nobody123
    Nobody123 Member
    160
    33
    United States
    2015 Prius Plug-in
    The only difficult step is accessing the nuts at the top. You have to disassemble the windshield cowl and maybe the wipers if you have big hands.
    The rest you can follow the video for anything, like a Corolla.
  12. SubCode
    731
    1,338
    Yeah I did it twice on my Scion XA....but those rear bolts look tough to get to...I've reached out to sfv41901 to help...thanks for reaching out to me.
    sfv41901 likes this.
  13. Nobody123
    Nobody123 Member
    160
    33
    United States
    2015 Prius Plug-in
  14. Jay J
    Jay J Active Member
    469
    253
    Torrance, CA
    The eccentric bolts on the arm don't really carry much of a sheer load.
