Looking for Explanation of what is on the gen 3 exhaust
Discussion in 'Gen 3 Prius Main Forum' started by Norryboy1a, Jul 22, 2021.
Tags:
  1. Norryboy1a
    Norryboy1a Junior Member
    Pennsylvania
    While trying to repair a noisy heat shield on my 2010 Gen 3, I noticed some strange pipes and what looks like some sort of actuator on the side of the exhaust between the cats and the main pipe going to the muffler. Looks like a resonator of some sort. Any idea what’s the function of it?
    51,495
    are you looking at the coolant heating loop?
    jerrymildred and Raytheeagle like this.
  3. ChapmanF
    17,710
  4. Norryboy1a
    Pennsylvania
    I really don’t know what it is. There is a hose connected to it that heads up towards the left side of the engine. I suppose that it could be some sort of preheater.
  5. Norryboy1a
    Pennsylvania
    The rattle that I thought was coming from the heat shield seems to be coming from that thing.
  6. ChapmanF
    17,710
    Have you clicked the link to read about the abgaswärmerückgewinnung?
  7. bisco
    51,495
    possible. try stuffing fire resistant materials like fiberglas in suspect areas and see if there's any change
  8. Norryboy1a
    Pennsylvania
    Just read it. Useful. Ich glaube meine Auspuff muss wechseln.
  9. Norryboy1a
    Pennsylvania
    Are there any part numbers out there for this? Looks like a future job.
  10. privilege
    privilege Active Member
    659
    169
    Birmingham
    oh cool ! didn't know about that !
    now I understand why the Prius coolant temperature rises from cold to operating temp so quickly compared to other cars.
  11. Mendel Leisk
    40,934
    Repair Manual info:
    privilege likes this.
  12. ChapmanF
    17,710
    Yes.
  13. Norryboy1a
    Pennsylvania
    Thank you very much. Now I understand more about why/if the mysterious rattle seems to be coming from nowhere. After looking at the shop manual, perhaps it’s a loose flap or an interior part of the exhaust heat recovery system. Looks expensive. I’m not sure of what / where the No. 3 meter circuit plate is though. I like to understand more about the serviceability and what is involved with the repair or replacement of the EHRS? Your help is appreciated. How much is a shop book? :)
  14. Norryboy1a
    Pennsylvania
    I’ll bet that it calls for a complete replacement. Thanks
  15. ChapmanF
    17,710
    If you follow the link there's a diagram, showing some of the parts as replaceable, others not.
    I would be pretty surprised if the source of the noise really turned out to be anything besides one of the heat shields in that general neighborhood. Those are common sources of noises (I've got one myself I'm avoiding at the moment), and the EHRS isn't.
    The no. 3 meter circuit plate (suboptimal Japanese to English translation of printed circuit board) is the circuit board within the combination meter (in the dash) that controls the temperature warning light.
  16. Norryboy1a
    Pennsylvania
    Thanks.
  17. Norryboy1a
    Pennsylvania
    Well, after careful inspection and testing all other rattling possibilities, it appears to me that there is some damage to the heat recovery system. Specifically the actuator seems to stoved and out of alignment. It must of took a pretty good whack to bend it
    like that.
    Please see the attached pictures. What do you think?
    #17 Norryboy1a, Jul 28, 2021
  18. Norryboy1a
    Pennsylvania
    A35190B3-028C-4BA2-B5F9-67A006AAD4F4.png FFDFB80E-236E-479E-80C1-F3D6A1858496.png
  19. Norryboy1a
    Pennsylvania
    I’m fearing that the rattle is internal. There doesn’t seem to be any other visible signs of damage though. Except the heat shield was beaten up a bit. There doesn’t seems to be no interference with the exhaust flow though.
