Looking for good air filter replacement
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by PriusC.Owner, Jan 6, 2014.
  1. PriusC.Owner
    PriusC.Owner Junior Member
    Greetings,
    I'm looking for a Toyota Prius C air filter replacement. K&N makes one. Does anyone have experience with K&N filters in their Prius C? Is K&N good or not so hot? Are any other brands available? Before I owned a Prius, I used Fram filters which worked fine.
    The reason I mention this is that the dealer wants about $40 with tax for an air filter. Installation is close to $60. It sounds high to me. They want even more dough to replace the cabin filter.
    On the plus side, cabin filters are a different part and I've had no problem locating replacements. The Fram CF10285 cabin filter is a great deal. If I can get the filter for around $15, the savings over dealer service goes into my beer and pretzel fund ;-)
  2. Mike500
    Mike500 Senior Member
    2,593
    767
    2013 Toyota Prius C Parts - Frank Toyota, Scion & Hyundai
    MSRP for a Prius"c" is $18. Which stealership did you go to.
    It takes 5 minutes to install it without tools.
    The K&N requires the same installation procedure, cleaning and oiling with a special oil.
    I'd get the cheap OEM filters.
  3. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    It's been covered may times on Prius Chat. The K&N filter does nothing for extra performance on the Prius engines and if you over-oil the filter you can coat the MAF sensor and degrade MPG.
    It takes about 1 minute to pop-in an air filter. What they charge you for is the LOST time it takes the tech to walk over the the parts counter and wait for/pick-up the parts. I suggest you buy the Toyota parts and put it in your self.
  4. rjdriver
    rjdriver Active Member
    409
    170
    Rhode Island
    Fram # CA 11426. $16.99 at Auto Zone
  5. Klaatu
    Klaatu Junior Member
    32
    17
    New Jersey
    Prius C engine air filters - who has them? Pep Boys. NAPA, Auto Zone do NOT stock the engine air filters for a Prius C. The dealers price $22.95. A little high for an item that costs $4.00 to make.
  6. rjdriver
    409
    170
    Rhode Island
    Ordered a Fram air at Auto Zone. Took 3 days to get.
  7. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    And the price was..........????
  8. rjdriver
    409
    170
    Rhode Island
  9. ETC(SS)
    7,367
    We have a winner folks!!
    $17 versus $100.
    Stay away from the K&N, unless you can tell me how shoving a $50 oily rag into your air intake is going to turn a 99 BHP car into a tire smoking monster, or get you more MPG.
    Spoiler Alert!!! It won't.
    Granted...it would be 1/2 the price that the %$#@!! CROOKS wanted to charge you!
    $100 for an OEM air filter?????!! :eek:
    How much do you think that they would charge to clean your MAFS or your intake when they get oil fouled by the K&N??
    My Advice:
    (Street Value: < $0.02)
    1. Out that dealer to Toyota Customer Care. $100 for an air filter replacement is self explanatory.
    2. Get an Aftermarket filter.
    3. Look on eBay or Amazon for the OEM unit in a handy 3-pack. Toyota's OEM air filter is actually pretty good and not that expensive if you don't go to the %$#@! stealership to get it.
    4. Replace aftermarket with OEM.
    5. Bask in the warm afterglow of a DIY job well done.
    Good Luck!
    Dominic Fong likes this.
  10. Mr Incredible
    Mr Incredible Chance favors the prepared mind.
    955
    506
    Neb
    I've had several K&N filters for different vehicles I've had.
    They aren't that difficult to master. Patience is the key. Clean them well and properly. Let them dry thoroughly. Don't over oil them. The problem is, who has the patience? I did, and I had a spare air filter to use on the car/truck while I was futzing with the K&N. It isn't hard, you just have to do it right. Over oiling is not that easy to do, but it can be done by the ham-handed DIYer.
    The filters really flow. But so does a new paper filter. They have done well in the applications where there is a lot of air flowing through like maybe my Z28 or V10 truck, but for a Prius of any sort I don't think they're warranted. There will be zero discernable improvement of HP or MPG.
    K&N filters are contra-indicated for saving money. Sure you never have to buy another air filter for that car/truck, but you do have to buy cleaner and oil each time you have to do maintenance on it, along with the high purchase price.
    After having lived with them for a while, I'd say we're all better off to simply buy new paper filters every spring. It wouldn't cost nearly as much as a K&N and we'd be a peak air filter performance at all times. Win/Win.
  11. priusCpilot
    priusCpilot Active Member
    663
    210
    LA
    I reported in a another post that there is a noticeable difference with the K&N on ICE on and OFF. It is a hint more seamless. No peak power. A little improvement in response.
  12. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    I used some fiberglass material from a AC house filter ( new ) cost me 50 cents. Did the same with the engine air filter. On my Gen 2. Plan to do the same on the C and the PIP.
  13. ETC(SS)
    7,367
    ^ In addition to a paper filter or replacing one?
    Hey it's YOUR car and you do as you please, but I'm pretty happy with paper filters. I've seen what the ducts in HVAC systems look like, and I've seen what throttle body assemblies look like.
    I'm thinking that the paper ones block more stuff.
    Good Luck!
  14. Easy Rider
    982
    210
    N. Central Florida
    If it was in place of the original paper........YIKES. :eek:
    Not only does that "fiberglass" have holes in it big enough to let June Bugs through, there is
    a HIGH probability that it will come loose and be sucked into the vent fan or the engine.
    A pretty high price to pay for saving a couple of bucks.
  15. Andyprius1
    2,327
    859
    Cool CA
    been doing this since 2005, and never a problem. Allows me to change filters as often as I like and bypass the dealer and all his Razzmatazz .
  16. ETC(SS)
    7,367
    I knew a guy who used to drive drunk all the time without a problem...but I'm not going to do that either.
    If you want to use HVAC filter media, to save $15 on a $31,000 car?
    Knock yourself out!
    Your car.
    Your call.
    This is one of many examples of why I buy new cars instead of used ones.
    It's (nearly) always more financially sound to buy a used car of course, but when I buy a new car and perform all of the maintenance myself, then I don't have to worry about people doing chemistry and physics experiments on my future car.
    Good Luck!
  17. Eclipse1701d
    Eclipse1701d Prius Enthusiast
    645
    224
    Nature coast, Florida
    Three Touring
    I don't know about you guys, but I blow out my air filter and cabin filter with an air compressor everytime I wash my car, which is at least once a month. My 15 month old air filter still looks brand spankin' new! I'm wondering how long it will last before it actually deteriorates? Does anyone else keep them clean as well?
  18. Easy Rider
    982
    210
    N. Central Florida
    YOu can't TELL if it is "deteriorated" or not because the tiny passages trap and HOLD the fine particles.
    They stick there and you can't, in general, blow them out.
    It likely is SLOWLY plugging up and you don't know it.
    Like the furnace filter thing, both are examples of "penny wise and pound (dollar) foolish".
    If you leave the dirt alone, it becomes pretty obvious when it needs to be changed.
    If you blow it off, you lose that visual clue.
    AND you can actually make matters worse if you blow in it the wrong way.
  19. Eclipse1701d
    645
    224
    Three Touring
    I physically remove it before I clean it, so I am not concerned with blowing any particles into the chamber, but thanks for the tip. I will replace it at regular intervals...
  20. PriusC.Owner
    Greetings,
    I ended up getting a Hastings Air filter (part #AF1563) for my Prius C. I went to Auto Barn and we had to order this part for the Prius C. Pricewise, it came to around $20 with the sales tax. In terms of dealer prices, they have to make money someway and I don't blame them for trying. I live in the New York Metro area. Dealer service tends to run on the high side up here. People get used to paying extra for things. You could liken it to going to a very expensive movie theatre concession stand where soda runs $10. Ah, but there lies the challenge! You can be cynical about it or shrewd. I prefer the latter to the former. Back when I first posted, that Prius C air filter was hard to locate up here. I started at the bigger chains -Pep Boys, Autozone. Finally, I ended up at Auto Barn. Well, they had the part and the price was fair enough.
    One thing I've noticed on these boards -some of the advice is much better than others. I'd rather pay dealer prices than do something that could hurt my car. That said, I'm also weary of posters who make everything sound super easy or have discovered some radical new & improved shortcut. As another poster noted, a Prius costs too much money to goof around on this stuff. Replacing your air filter with a part that's designed to fit a Prius C is one thing. Paying a small fortune at a dealer for the service is another issue. I feel like the guy at the beginning of the movie "Tin Men". All he wants is a fair deal on a car with no special gimmicks. For some reason, it wasn't the easiest thing to do and it was good for some laughs.
