Looking for help/links/advice...
Discussion in 'Gen 2 Prius Accessories & Modifications' started by WilDavis, Jul 18, 2017.
  1. WilDavis
    WilDavis Senior Member
    2,492
    2,153
    49
    I'm looking to add a decent horn to my 2009 Gen II, I think I'll leave the existing wimpy horn as it is to be used only when I don't want to give any poor unsuspecting recipient a LaundryExperience, and just wire in something with a bit more authority (I've been looking at the Wolo BadBoy from HarborFreight) - I have no problem with the electrics and wiring and fusage etc. (EE way back in the early 1970s), but I've found the ideal place for the push-button (right next to the dimmer-switch to the left of the steering wheel), and I'm wondering (1) how easy it is to remove/modify that panel, and (2) how to get through the firewall. Any help/instruction is much appreciated, so thanks in advance!
    49,507
    i have never used my horn. what does it sound like?
    Raytheeagle likes this.
  3. WilDavis
    2,492
    2,153
    49
    Well, mine is a sort of meep meep meep whisper! …whereas the WoloBadBoy is more of a WHAAAAAA! WHAAAAAA!
    49,507
    i just wet myself.:oops:
    Raytheeagle and WilDavis like this.
  5. JC91006
    16,482
    8,400
    You really need to add an electronic air horn to have the right effect.
  6. WilDavis
    2,492
    2,153
    49
    True, but I added a couple of Maserati Air Horns to my VW Rabbit (about 30 years ago when I first came to USA) and when I came to sell it, the young buyer fell in love with the Air Horns, so those are what sold the car! (same set up, original horn operated by centre of steering-wheel, and Maseratis on separate button!) I want a similar set up on TheChuggyPig!
    JC91006 likes this.
  7. a_gray_prius
    2,927
    782
    IL
    How about some Hella Supertones? I see them on a ton of modded cars.
  8. WilDavis
    2,492
    2,153
    49
    Whilst your replacement suggestion is much appreciated, the real purpose of my original post was to (1) find out how to get into the blank panel to the left of the dimmer-control, and (2) how to get through the firewall. …any ideas? …anyone?
  9. The Phoenix
    The Phoenix Member
    217
    84
    Fredonia WI
    Four Touring
    I have done what you are asking about and I have found a way, possibly a little unconvential but it worked really well I documented it under the thread what did you do to your prius today...I will try to post a link to that thread but not sure how hold on
  10. The Phoenix
    The Phoenix Member
    217
    84
    Fredonia WI
    Four Touring
  11. The Phoenix
    The Phoenix Member
    217
    84
    Fredonia WI
    Four Touring
    I'm not sure what happened to my other post....maybe I just can't see it...its super easy to get to that panel and I by passed the firewall all together and went in underneath. If you have any questions just private message me or respond here
  12. The Phoenix
    The Phoenix Member
    217
    84
    Fredonia WI
    Four Touring
    Watch the very first minute of this you tube video to get access to the switch blanks
  13. The Phoenix
    The Phoenix Member
    217
    84
    Fredonia WI
    Four Touring
    Sorry for flooding your post with nonsense you don't need anymore I see you have already finished your project, sorry for not checking the dates of your other posts
    WilDavis likes this.
  14. WilDavis
    2,492
    2,153
    49
    Thanks anyway, and don't forget, even though there is often Too Much Information :rolleyes:,as far as I'm concerned (particularly in Prius-related matters) No Information Is Ever Wasted! :rolleyes:;)
