Looking for hybrid mechanic in Silicon Valley/Steering wheel buttons not working
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by devprius, Feb 8, 2012.
  1. devprius
    devprius /dev/geek
    979
    291
    San Francisco Bay Area, CA
    I've got a 2005 Prius with 160K miles on it that needs some work. I'm a little loathe to take it to the dealer, and would like to find an independent mechanic.
    The main problem I'm having is that the Info & Recirculate buttons on my steering wheel no longer work.
    I think the Recirculate button is stuck somehow, because when I try to press it, there is no travel and I can't easily put the car into Recirculate mode. The Front and Rear defrost buttons do work properly.
    There is plenty of travel for the Info button, and it feels like there is a button press happening, but the signal isn't making it to the MFD. The Map button works properly. The Handsfree buttons also work properly, as does the Voice-command button.
    All the buttons on the left side of the car also work correctly, and have the right amount of travel.
    An alternative is for me to replace the button clusters myself. The parts themselves are about $100 to $125 per cluster. How easy is it to remove them?
  2. hyo silver
    hyo silver Awaaaaay
    15,232
    1,562
    off into the sunset
    A 'hybrid' mechanic? I try to stay away from the knuckle-dragger neanderthal types. Mind you, a hybrid of human and computer would be great. ;)
  3. dogfriend
    7,512
    1,185
    Carmichael, CA
  4. The Critic
    The Critic Resident Critic
    3,193
    2,319
    CA
  5. drew935
    drew935 Member
    168
    22
    Nor Cal
    /\/\ Wow, they look pretty good to go to. I have my friend at Capitol Toyota that takes care of me.
    Here's the fsm that will help you out.
    Documentazione Tecnica Prius 2006
  6. CHockMT
    CHockMT Junior Member
    Montana
    Fast forward to 2017: What fixed the Info and Recirc buttons? My 2010 has inop Trip and Mode buttons on the steering wheel.
  7. CHockMT
    Montana
    Correction: Display button inop, not Mode.
