looking for owners reviews Gen 4 to Gen 5
Discussion in 'Gen 5 Prius Main Forum' started by MarkOlin, Jan 3, 2025.
  1. MarkOlin
    MarkOlin Member
    78
    39
    Buffalo, NY
    2020 Prius Prime
    I'm currently an owner of a 2021 Prime. I like my car a lot. I have to admit I'm really liking the look of the new Primes. Wondering what actual owners think that made the switch from gen 4 to gen 5.
    For me, a few things that are holding me back are:
    - longer charge times.
    - less head room
    - in/out access.
    Feedback will be appreciated.
    daisy555 and tovli like this.
  2. Drew_priuschat
    Drew_priuschat Junior Member
    23
    2024 Prius Prime
    XSE
    I am surprised no one has commented yet, ill give my responses to your questions but keep in mind I came from a 2014 corolla and not a gen 4 Prius so similar but also very different.
    Charge times, this really hasn't been much of a concern for me as I charge overnight and my commute is rather short, it charges in approx 10-11hrs on a standard 120v receptacle from empty, the last hour only does a couple of percent(I think it balances the cells but no clue honestly). I will also add that I've been charging in my driveway with no issues after installing a weatherproof in use cover for the receptacle outside, I do however avoid charging during heavy rains. If you get a level 2 charger installed that will significantly drop your times.
    Less head room, I'm not gonna lie I am pretty short and so is the rest of my family so this doesn't really apply. I will say that when I first go it I did feel a bit claustrophobic coming from my corolla but that was due to how the windshield swoops and not actual headroom, I got used to it quickly.
    In/out access, this one could genuinely be a concern if you have any mobility issues. The car feels very low compared to a lot of other sedans and suvs so you do need to drop into the seat which could be a challenge for some. I will say that my grandmother that is in her 70's did just fine getting into the back seat but she doesn't have mobility issues so take that as you will.
    As for some other comments, I will say this car seems to have 12v battery issues that haven't really been commented on yet by Toyota as far as I'm aware. I have had to get my 12v battery replaced like many others and there doesn't seem to be much clarity regarding why, plenty of theories though if you look around the forum. I will say that I LOVE the extra performance this car has over my corolla, its not a sports car but going from a standard economy car to something with a bit more pep was very good for the soul. The range is also much better going from gen 4 to 5 so that may be a factor for you as well, for me it means I can go to work do all my errands and come back fully electric with zero issues, even in winter(above -10 as the engine kicks on below that for heat). Im open to answering any other questions you may have regarding the gen 5 but, I cant really compare to a gen 4 as I've only rode in one and haven't driven one daily.
  3. Deathcommand
    Deathcommand New Member
    2023 Prius Prime
    SE
    I'm a Prime 2019 to 2023 owner.
    Longer charge times are not an issue for me. I have it charge slowly from 10 - 7 because of the cost of electricity being higher from 4- 9. If it fully charges, it fully charges, If not, I'm more than happy to drive it in Hybrid mode. But more often than not, it has been fully charging overnight.
    Headroom has not been an issue for me. The only thing that I don't love is worse visibility, but I just move forward and back whenever turning, which I did anyways just to be safe in virtually every car. I would say, if you are in a city or a place with lots of pedestrians, it might be a little worrysome as they would be more difficult to see than a car. Anyways 5'9", no issues with headroom. In-out access is definitely worse, but I'm still relatively young (31 RIP) so I'm still alive.
    I highly suggest renting one from toyota or whereever else. It's worth it for a large purchase.
    I didn't, but I got lucky and I'm an idiot. Just rent before you buy.
  4. Trollbait
    12,468
    The longer charge time comes with more EV range, and is only longer if you make use of that range. The efficiency between the two is close. So if you aren't going to be driving further on EV with the new model than you already do with the 2020, charging up the used electricity will take about the same time. It is only longer if you completely drain the grid charge.
    The questions about access and seating are ones best answered by sitting in the car yourself, and the hybrid model will do for this.
  5. Downrange
    Downrange Active Member
    372
    209
    2024 Prius Prime
    SE
    I did a lengthy comparison a year ago when I traded my 22 Prime for a 24 Prime. I'm taller than most, but have adapted to the ingress-egress issue pretty well, and I have enough headroom. I appreciate the extra EV range daily, and find the charge time only marginally longer. I like the styling MUCH better, as well as the slightly quieter cabin noise level, and significantly enhanced acceleration on demand. I'm not certain, but feel the 22 got slightly better highway mileage, mostly because of the smaller engine, which is used almost 100 per cent for highway travel. I also tend to drive 75-80 most of the time, and this pulls mileage down a lot. I do perceive a general cheapening of the interior in the 24, although it looks fine, it seems more flimsy and lacking a bit in substance and quality of finish. I also like the slightly larger rear storage in the 22, and as far as the rear seats, let's just say I'm glad no one has needed to ride back there in the past year! All in all, I'd definitely do it again!
    Gokhan likes this.
  6. ArtVanDelay23
    ArtVanDelay23 Member
    61
    62
    ny
    My family owns a 2017 & 2020 Prius Prime. Our only complaint with the previous generation was a lack of donut or full-size spare tire. We needed a 3rd vehicle and went with a RAV4 Prime. The vehicle is significantly nicer than a Prius and with the $6500 cash back in some states made it an easy decision.
    After only buying Prius vehicles since 2006, we couldn't justify the cost of a 2024 Prius with 17inch or 19inch tires.
  7. Gokhan
    Gokhan Senior Member
    6,064
    2,404
    Paramount CA
    First of all, Gen 4 and Gen 5 are nearly identical cars other than the exterior styling. Under the hood, they are nearly identical other than a slightly bigger engine and motor. So, you won’t feel much difference if you upgraded.
    I see you got the LE; so, you don’t have the BSM. If I had the same car as you, the only reason for the upgrade would be BSM and TSS 3.0. If yours is a 2021, you got TSS 2.0 or TSS-P if a 2020.
    If you need the extra BEV range, that could be a reason for an upgrade, too. Technically, the Prius PHEV is not meant to be driven on the highway in the BEV mode but only in the city, as the battery is too small for regular highway driving and could wear out quickly.
  8. Blackat
    Blackat Active Member
    447
    309
    Colorado
    2023 Prius
    Limited AWD-e
    The Gen4 was too fugly for me to even consider.
  9. BlueMagnet
    BlueMagnet Member
    51
    27
    San Bruno, California
    2023 Prius Prime
    SE
    Went from a 2017 Prime Adv to 2023 Prime SE. Gen 5 is soooo much more fun to drive. Feels like a sports car on
    the road. Never knew a few added horsepowers would make a difference. I'm very short so getting in and out is slightly more
    difficult since front seat needs to be all the way forward and my head hits the top of the car getting out. Not a
    big issue - just need to turn my head to the side. Charging time is more to get more battery distance - makes a difference when just doing
    errands around town without running out of battery.
  10. Deathcommand
    2023 Prius Prime
    SE
    In what world are you comparing these two? They absolutely feel worlds apart.
    Blackat likes this.
  11. JoeBlack
    JoeBlack Member
    112
    89
    Europe
    2021 Prius PHV
    I had 4th gen PHV for more than a year and right now it's year and half I am driving 5th gen PHEV.
    IMHO, almost everything in 5gen is better, but the visibility for the driver is considerably more limited. Still after more than year I have trouble taking sharper, narrow corners - I never bumped into anything, but in older Prius, Camry, Yaris Cross, Subaru Levorg had no such issue.
    I miss the white interior option, better position of "shifter" where it could not possibly get in the way and carbon hatch :)
    Drew_priuschat likes this.
  12. Drew_priuschat
    23
    2024 Prius Prime
    XSE
    YES the sharp corners are still a thing that bugs me, I drive a full sized transit and I feel more confident taking sharp turns in it than the prius, something about the hood and pillars make it a bit tricky to properly guage, I will say that having the front sensors helps a lot though
    JoeBlack likes this.
