I'm popping into the gen4 forum because you guys are more likely to still use regular Techstream instead of Global Techstream. I've got a problem with my car and GTS+. It's a known bug issue, and there's no great solution yet from Toyota. It involves programming a sensor ECU. For whatever reason, GTS+ can't download the correct ECU config file for this particular sensor on a gen5 Prius. In desperation, I'm wondering if Techstream v18 might be able to work. My car's a 2023 that came out right at the transition between the systems. I've got a Mongoose-Plus and I'll get the Professional Diagnostics subscription to TIS, so I don't think I need a cracked copy of Techstream, just a normal one. But I'd rather my laptop not be infected by seventeen different types of malware while attempting this. So does anyone have a safe copy of v18 or know where to find one? I'd massively appreciate it. Thanks
