Looking for the "snakes in the woodpile"
Discussion in 'Gen 3 Prius Main Forum' started by James Blunt, Jan 13, 2025.
  1. James Blunt
    James Blunt New Member
    Frederick MD
    For those not familiar with that phrase, it means I'm looking for those hidden things that will bite me. Anyway, looking to buy (for my grandson's first car), a Gen 3, trim level lll, 125k, well kept that is being put up for sale because present owner needs something bigger. Generally, what kinds of problems should I look out for now and anticipate in the future. Battery?
    I wanted to get the opinions and experience of the experts.
    Thanks in advance, folks!
  2. Tombukt2
    Tombukt2 Senior Member
    13,408
    2,415
    Durham NC
    This is something you want to rethink immediately You're looking at cars that are now what 10 years old minimal or generation 3 stopped in 2016 or something 2015 and it's 2025 definitely rethink this for a kid teenager or 20 something year old a Corolla or a Yaris will keep your sanity and his a lot longer If you want calls everyday about a light coming on and another light coming on and something flashing and so on and so forth for the next five or six years until you can get out of that which is what that will become save yourself a bunch of trouble The Corolla and the Yaris have no batteries for traction and electric motors they have reliable engines and easily go two or $300,000 miles and get a few miles to the gallon less than the Prius with none of the maintenance issues and I mean almost none Read here for all of the gen 3 maintenance and nonsense issues and you will run very quickly from this particular series Gen 3 and 4 I wouldn't fool with personally there are many here who will and are It cost money for a few extra gallons of fuel mileage can be very costly You can be an a Gen 3 with $7,000 and still not be moving It is possible people have done it many times these things are boat anchors sitting around people's yards all over the east coast and then he will tell you they are just not worth fixing but you do what you feel is best remember this text when the time comes
  3. Brian1954
    Brian1954 Senior Member
    2,408
    964
    South Central PA, USA
    Just do a search on this forum. There are a few posts every month about this same question.
  4. Leadfoot J. McCoalroller
    8,147
    7,646
    Pennsylvania
    2018 Prius c
    *deep breath*
    The hybrid battery tends to last 12-15 years in that model, so count from the year it was made.
    The brake booster is a $3,000ish problem that can affect these cars at about the same age.
    Head gaskets are problematic on that model- there's a long running argument regarding the cause, but either way the early symptom is a rough clattery engine start. If you catch it quick a replacement gasket and a new Toyota water pump will probably keep it going a long time.
    If you don't catch it quick, a replacement engine rapidly becomes the best cure.
    This one is complicated if the seller either doesn't know that the head gasket is compromised, or doesn't know how long ago it started, or is not truthful with the buyer about the status and timing of the problem.
    And it's difficult to verify air conditioner function in a Maryland winter, but every bit as expensive to fix a non-functional one come summer, so watch for that.
    The very short version: A Prius is a very complicated car, and when complicated things get old they get expensive. Not a good choice for saving money, especially when gas prices are this low and many non-Hybrid cars are also getting good MPG. Corollas, Civics, Fits, Sparks, Accents and even Versas are much better choices for students.
  5. ChapmanF
    18,545
    This one might not be so difficult with a capable scan tool. The A/C will run with the windshield defogger. With a scan tol you can watch the watts consumed by the electric compressor, and watch the refrigerant pressure on the high side.
    I think I've seen where a later generation's A/C ECU will even calculate based on the wattage, pressure, and temperature, and report whether the refrigerant charge is correct, though I haven't seen that with my own eyes.
  6. Leadfoot J. McCoalroller
    8,147
    7,646
    Pennsylvania
    2018 Prius c
    In an absolute sense that's pretty nifty, and not too bad of a workload for the benefit.
    But in the context of the average buyer kicking tires on corner lots I'd still rate that process as 'difficult.'
  7. Lori V
    Lori V New Member
    CT
  8. Lori V
    Lori V New Member
    CT
    As an owner of the Prius since 2007 ( 2 2007's, 1 2012, 1 2015, 1 2022) I would shy away from a Gen 3 ( i believe 2010-2015). Due to a poor piston ring design, they start to burn A LOT of oil around that mileage range. I had to check oil EVERY gal fillup and carry a quart with me at all times. Engine finally blew (probable head gasket, evidence of water in engine, but engine not dismantled to verify) at about 220k. The 2007 also did this but made it to about 160k before engine seized (son didn't think to check oil). We are mechanically handy with equipment, so were able to replace 2007 engine in 2019 (65k on replacement engine) ourselves for $1,200 and it's still running strong, including hybrid battery, although various electronic interior buttons are failing. 2012 engine has been pulled out and we are waiting on a replacement to arrive, but this engine is direct from Japan and has to have all the auxiliary components reinstalled to meet US emissions. If we were to send it to a mechanic to do it would easily be 5K. I would seriously look at a newer version with under 100K for a teenager, as no one needs a panicked driver should something go wrong engine wise and particularly hybrid battery wise.
  9. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    If you love your grandson, avoid this vehicle. If you want to show some tough love and get revenge on him, this is the perfect vehicle.
  10. ChapmanF
    18,545
    Was "around that mileage range" around 125k, the mileage mentioned by the OP?
    That's about what my 2010 had when I bought it. I may jinx myself by writing this, but it's around 190k now and still reads nearly unchanged on the dipstick by oil change time. I've been changing at 5k miles and think the first owner did also. I wonder what interval has been used for the ones that become big oil burners.
