Looking for used alloy rims
Discussion in 'Generation 1 Prius Discussion' started by osiris12, Dec 20, 2010.
  1. osiris12
    osiris12 Owner of 3, yes three priuses
    119
    Upstate NY
    Looking for used 2001 Prius alloy rims in the 12590 zip code. Every year I have snows mounted on my car and it is getting to be expensive ($80 twice a year).
    I think it is time to mount my set of 4 snows so that I can changed them at will.
    Anyone selling used 2001 prius rims?
  2. TexomaEV
    TexomaEV Member
    154
    Bonham, Texas
    2001 Prius
    I wonder if other Toyota Model Vehicles, might have rims that fit the Prius? You might find some steel rims you could put the snow tires on and use hubcaps to dress them up a bit. This way if they get damaged somehow, it wouldn't be an alloy rim. Do you have a salvage yard near you, that might have several models of Toyota's you could look at and measure the lug pattern?
  3. osiris12
    119
    Upstate NY
    Thanks for the info. The 2001 uses 14 inch 5.5 bolt 4x100 rims. I should be able to find those a lot easier than looking for used prius rims, since the '01s are as rare as Anatase
  4. Mendel Leisk
    38,247
    Check with dealerships: I was able to get snows on Corolla 15" black steel rim (p/n: 42611-02471) for our 2010. New cost me $70 Canadian per, take-off might also be available. I was also sold simple open-ended lug nuts, the type used for steel rims with covers. You can likely use your alloy rim nuts, but they look a little odd, and with the extra nuts not that expensive it saves the alloy nuts from salt exposure.
  5. jk450
    jk450 New Member
  6. a_gray_prius
    2,927
    782
    IL
    I'd imagine that since the 01/02 Prius is based off the Echo, why not look for some echo rims?
  7. ChapmanF
    15,102
    Don't forget the JJ in "14 x 5.5JJ". Pretty sure it means something, even if I'm not sure exactly what. :)
    (I did know, once when I was researching my tire thread a while back, and I think it's a particular standardized shape of the rim profile.)
    I have one slightly flattened alloy rim if you want it. ;)
    -Chap
  8. freidawg
    freidawg Prius Recycler
    111
    35
    Denver, CO
    2003 Prius
    I have these in stock and can UPS them to you.
    Eric
    Adopt A Part
    800-508-2211
  9. osiris12
    119
    Upstate NY
    Well, I've away from this board way too long. Sorry about that Eric. Do you still have those rims:)
  10. ea8631
    ea8631 Member
    186
    Toronto, Ontario
    Technology
    This is what I used in my 2001 prius for these 10 winters and I have no problem for that.
  11. osiris12
    119
    Upstate NY
    Thanks for the reply. I will give them a try. Not looking for anything fancy. Even a steel rim will work for the winters.
    Used is even better. Guess i'll make a trip to my local Auto Grave Yard and see if I can pickup a set.
  12. ea8631
    ea8631 Member
    186
    Toronto, Ontario
    Technology
    Make sure you ask for the 14 inch since back then 13 inch is standard and 14 inch is option for ECHO.
  13. 2002_Pri_Rod
    2002_Pri_Rod Member
    92
    68
    Forestville, CA
    2002 Prius
    Sorry to resurrect old thread but I have a set of rims I would sell
    Also is it appropriate to offer things up for sale in Prius chat?
    Litehold likes this.
  14. dolj
    dolj Senior Member
    7,505
    3,772
    Wellington, New Zealand
    It is in the "for sale" section.
  15. litesong
    litesong Active Member
    371
    122
    Everett, WA
    I've bought used wheels & tires, readily & cheaply from Craigslist....even got free tires. Two of my cars are traveling on used wheels & tires, & I love them!
  16. 2002_Pri_Rod
    2002_Pri_Rod Member
    92
    68
    Forestville, CA
    2002 Prius
    Thanks - did not know there was a for sale section - will check it out
  17. Hipstor
    Hipstor Junior Member
    Las Vegas, NV
    According to my local junkyard. Using interchange info ©2016 by Audatex North America, Inc. My Gen 1 2003 Prius can interchange rims with..
    Tercel, 93-96 (spare with ABS)
    Paseo, 93-99 (spare with ABS)
    and of course
    Prius, 01-03 (spare)
    The non Prius cars don't match style wise. But the rims will fit. Same bolt pattern (4 lug, 100mm) and tire size (R14). I pulled a Paseo rim/tire for my car, cause I bent my original rim. Paseo rim is stamped "14x5.5JJ" right under the hubcap. 5 spokes instead of 8 though. So now I roll around with 1 mismatched wheel. Can't beat the junkyard's price. $41 for an alloy rim and nearly new tire. Still had mold hairs on the tire. :cool:
    Now, how do I get rid of my old bent rim and damaged sidewall flat tire? :unsure:
    WHCSC likes this.
