Looking to buy a 4th gen. What to look for?
Discussion in 'Gen 4 Prius Main Forum' started by Zradub, Sep 12, 2022.
  1. Zradub
    Zradub Junior Member
    40
    I’m looking to get a 4th gen. What should I look out for? And is there a classified section here, if so it is pretty well hidden? Thanks
    51,719
    There’s a cars for sale forum, but it’s rare to see anything there.
    As for a gen4, good luck finding one. The only thing I can think of is to see if the exhaust coolant heat exchanger has been repaired.
    All the best!
    51,719
    “Private sales” down near the bottom of the main forums page
  4. MalachyNG
    MalachyNG Active Member
    304
    225
    Northern NY
    2022 Prius Prime
    Really whatever you normally look for in a used car purchase. Gen 4 came out starting 2016 model year.
    Trims and options have changed a little through the years but it's still the current generation of Prius.
    Some earlier years in the run have had coolant leaks into the exhaust system as bisco mentioned. Some shops may misdiagnose that as a blown head gasket. Beyond that, not much that has shown up as far as common issues.
    Run a carfax on any used cars and have your mechanic or a trusted 3rd party prius or hybrid mechanic look over any used examples you're considering buying. If a seller refuses that then move on find another seller.
    Priuses are hot tickets with gas prices still high. You may need to cast a wide net and consider traveling out of state to find what you want.
  5. Zradub
    40
    Is the coolant leak into the exhaust system an expensive fix?
  6. MalachyNG
    304
    225
    Northern NY
    2022 Prius Prime
    There's a TSB and Toyota is replacing the part under warranty (96 months or 80k miles, 180 months or 150k miles in CARB states). Outside of the warranty it could be $1500-2000. So far it seems rare. If you're looking at high mileage cars it's a cost to consider
    #6 MalachyNG, Sep 12, 2022
  7. Zradub
    40
    Once it’s fixed is it fixed or is it something which will occur every ‘x’ miles or years? Thanks again for the help.
  8. ColoradoBoo
    ColoradoBoo Senior Member
    1,217
    801
    Monument, Colorado USA
    We have a 17 and a 21 and have not had any issues, not even the coolant leak at the exhaust exchange. (I keep an eye on those.)
    Ask for maintenance history....I've heard of Gen 4's starting to burn oil and/or lose a head gasket when the owners didn't get the oil changed at least every 5,000 miles. If no maintenance record is there, ensure ICE engine is checked out by a mechanic. Other than that, solid cars so far!
  9. bisco
    51,719
    once it's fixed, it's fixed
    ColoradoBoo likes this.
  10. sclevine
    sclevine Active Member
    158
    153
    Northeast Florida
    2024 Prius
    Fix is to replace catalytic converter. Set me back $2100. It occurred to me 5 years and 190,000 miles into ownership. I really can't complain though because this car has still been way cheaper to maintain than any other I've own.
