Looking to buy a prius 3
Discussion in 'Prius Cars For Sale' started by ToyotaCoyotta, Jan 11, 2025.
  1. ToyotaCoyotta
    ToyotaCoyotta New Member
    26
    Lithuania
    I am looking to buy a Toyota prius 3rd gen Somewhere in europe,
    Germany, netherlands, france, italy, belgium
    Looking for a well maintained not more than 200.000km,
  2. Tombukt2
    Tombukt2 Senior Member
    11,997
    2,120
    Durham NC
    I feel for you .. Prius don't like to sit in car parks. Corollas and Yaris don't mind at all
    ToyotaCoyotta likes this.
    51,018
    due diligence on the oil burning, clogged egr circuit, blown head gasket, brake actuator problems.
    all the best!
  4. T1 Terry
    T1 Terry Active Member
    727
    395
    I'd look for a manufacture date close to the end of the Gen 3 production run, less likely to have the head gasket issues.
    I wouldn't worry too much about the odometer reading, but be aware of the EGR problems and check for "blow by" and blocked crankcase ventilation by warming the engine up, then placing a piece of paper or beer coaster, over the oil filler hole once the filler cap it removed .... it should hold there, even with the motor revved, if it doesn't, look for another unit if you can't confirm it is just a blocked crankcase recirculation problem .....
    T1 Terry
  5. Grit
    Grit Senior Member
    6,411
    4,181
    Wilkes Land
    We re always accepting new egr cleaning members!!! Buy a turd gen Prius and get a lifetime membership for 50% off, Azusa pc member has a code to save you 5%!
  6. rjparker
    rjparker Tu Humilde Sirviente
    9,492
    5,812
    Texas Hill Country
    You can buy a 2021 gen3 Prius v/alpha/+ over there with factory lithium and bms.
  7. ToyotaCoyotta
    26
    Lithuania
    Thank you so much for the advice, any such advice will help me when checking a car
