Loose ground wire hanging, help..
Discussion in 'Gen 2 Prius Technical Discussion' started by Gaprofitt, Nov 27, 2009.
  1. Gaprofitt
    Gaprofitt New Member
    28
    Atlanta, GA
    Hi All,
    About a month ago I was in a wreck, $8700 worth of damage. I just got the car back and everything seems fine except for one thing. There is what appears to be a ground wire that wasn't reconnected. It's connected right behind the air filter to the engine block but the other end isn't connected to anything, it has a round electrical connector on the end. It's a 2007 model, anyone know what this is suppose to connect to? If not can smoeone take a look and tell me where it goes?
    Thanks,
    Greg
  2. dogfriend
    7,512
    1,185
    Carmichael, CA
    There is a wire with black insulation with a white stripe which is attached somewhere under the air cleaner. The other end attaches to the body of the car under the LH corner of the plastic radiator cover.
  3. Gaprofitt
    28
    Atlanta, GA
    Is it possible to get a picture? I can't find where it connects near or under the radiator cover? It's definetly a black wire with a wipe stripe. I appreciate the help.
    Greg
  4. dogfriend
    7,512
    1,185
    Carmichael, CA
    I was going to ask you that earlier. :madgrin:
