Loose heat shield
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by lenjack, Mar 23, 2018.
  1. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    My 2010 with 120k miles started making rattling sounds 3 days ago. It's the heat shield. How urgent is it to have it repaired, replaced, or preferably removed and ignored? I never park on anything remotely grassy or flammable.
  2. Mendel Leisk
    38,738
    Isn't the heat shield protecting the car body? Not sure. I'd have a look, would suspect there's one or more fastener missing, or if you're lucking just dislodged, and or the heat shield hole has torn. In the latter case an oversized washer might solve the problem.
    If fasteners are missing, I'd make sure to get the correct ones through a parts department.
  3. lenjack
    804
    114
    Pennsylvania USA
    My very knowledgeable and trustworthy garage guy is going to take a look. Thanks.
