Loose Part Behind Steering Wheel
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by keymusic, Jan 14, 2017.
  1. keymusic
    keymusic Active Member
    205
    110
    Southern California
    #1 keymusic, Jan 14, 2017
    49,492
    my car has a loose nut in front of the wheel.
  3. keymusic
    205
    110
    Southern California
    Funny
    Rpowers47 likes this.
  4. alanclarkeau
    alanclarkeau Senior Member
    7,044
    7,584
    near Brisbane, Australia
    It's the mounting for the 2 wands, and if you feel/look below to where it goes, it's quite long.
    It needs to enable the steering wheel to whirl round and round within it. It also needs to move up and down separate to the solid dashboard to adjust the up/down angle and in/out position of the wheel. So quite a fair few things happening there, it can't be attached hard to the dashboard (or the wheel obviously) - I couldn't see quickly what it attaches to, but I'd guess it would need to be flexible.
    Nor was I going to try adjusting my wheel up/down or in/out because it took a while to find the RIGHT position for me - but try adjusting the wheel position and let us know if it moves more still.
    I don't have access to another car to check, but I'd be surprised if any cars mount that piece solidly. Have a look at another make/model of car to see how they approach the issue.
  5. keymusic
    205
    110
    Southern California
    Yes it's still loose regardless of the position of the steering wheel. My son has the same car and his isn't loose. So I was checking with others before I take it to the dealer.
  6. alanclarkeau
    7,044
    7,584
    Mine is more or less the same as yours.
    keymusic likes this.
  7. alanclarkeau
    7,044
    7,584
    ... except the wheel is on the RIGHT side ...
    keymusic and bisco like this.
  8. RCO
    RCO Senior Member
    3,709
    5,184
    Cornwall
    Better than any loose nut behind it though! :barefoot:
    kithmo, keymusic and bisco like this.
  9. ePWR
    ePWR Member
    131
    137
    PRIUSchat
    mine is solid.
