lose of power and warning lights on Dash
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by RogerRios, Jul 2, 2014.
  1. RogerRios
    RogerRios Junior Member
    Fallbroook Ca
    My Prius is 07 with 146k in southern California, for two days every morning I took a short trip to a store then when driving back home the prius battery lost bars fast and I lost power with all sorts of warning lights. Then I drive off with no problems for the entire day. I disconnected the aux battery and that reset the Error codes, I checked the inverter pump and works properly, I checked the aux battery and shows 12v when off and 13.9v -14v when on. This happens every morning so I suspect it's the aux battery. 3months ago my dash lights went out and rebooted the car with no problems.
  2. JC91006
    16,482
    8,400
    you are still within CA warranty on the hybrid battery, if that's the problem, the dealer will give you a new one. Why are you resetting the codes? When this happens, bring it to the dealer before your warranty ends at 150k miles.
  3. RogerRios
    Fallbroook Ca
    Well this morning it did the same thing and noticed that the battery discharges in less than 5min from green to purple when idling. I'm now going to read the codes to confirm that it's the main HV Battery.
  4. RogerRios
    Fallbroook Ca
    I made the obd2 scan and it showed code P0A80 It's the HV battery pack
  5. bisco
    49,484
    wow, you couldn't have timed it any better! all the best on the next 147,000 miles!(y)
  6. JC91006
    16,482
    8,400
    Wow 07 cars getting failures now. They are trickling down.........congrats on the lottery win (y)
