Lose Radio Presets in my Prius v (lowercase v for Prius v)
Discussion in 'Prius v Audio and Electronics' started by Janet Hart, Dec 20, 2014.
  1. Janet Hart
    Janet Hart Junior Member
    AZ
    2013 Prius v wagon
    I've had this 2013 Prius v (lowercase v for the Prius v wagon) for about 6 months. During that time on at least three or four occasions I've lost all my radio presets. They just disappear and are replaced with stations I don't use. It seems to happen in between car usages, not while driving, but I am not sure about that. I am not noticing any other problems. It's a HD radio. I did not continue Sirius after the introduction period. Any ideas? Thanks in advance for any advice.
  2. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    The only thing powering the car when off is the 12v battery. If your battery has been abused then it could close to death and when the voltage drops enough the radio will lose power. When the radio loses power you lose your presets. Abuse is things like leaving the dome light on all night, headlights on for a bit, anything that requires a jump, long idle periods where you don't drive it for a while including sitting on a dealer lot for months waiting for a new owner.
    If left untreated eventually you will start losing other learned things like the auto-up window functionality and that sort of thing.
    GrumpyCabbie likes this.
  3. Janet Hart
    AZ
    2013 Prius v wagon
    Oh. Thank you very much for the fast reply. The car was a leftover, so it was on the lot a while before I got it. But to my knowledge I have not done anything like that. Nor have I had any other problems (that I can tell.) It's not like there is an incident. It just occasionally happens. But it sounds like I should be getting it back to the dealer ASAP. What will they do?
  4. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    257
    Ocala, FL
    Hopefully they will test the 12 V battery, find it weak and give you a new one under warranty.
    You should insist that they test it, regardless of what else they might do.
    It is possible that the battery will not test bad and then you have to decide whether to argue with them or just buy a new one (~$200).
    Does much of your driving consist of fairly short trips, separated by sitting idle for several days ?
    If so, getting a small automatic battery maintainer (charger) would probably be well worth the money.
    Actually I think that every car owner should have one.
  5. Janet Hart
    AZ
    2013 Prius v wagon
    Thank you. No, we drive it pretty much every day and this last incident happened after a 120 mile highway trip. But thank you, anyway, for the tip about the batter charger. I will call the dealer now.
  6. rjparker
    rjparker Tu Humilde Sirviente
    7,920
    4,687
    Texas Hill Country
    It is also possible to reset the radio through a setup screen. Maybe someone accidentally did it.
  7. Bill the Engineer
    1,048
    2,278
    467
    At the beach in Delaware...
    You do realize I hope that there are two sets of FM presets in the car. You toggle back and forth between them by pressing the FM button more than once.
    Bill the Engineer
  8. rdgrimes
    rdgrimes Senior Member
    1,740
    446
    New Mexico, USA
    2018 Prius Prime
    If so equipped, the mode button on the steering wheel will do that too. Learned that one the hard way.
  9. Janet Hart
    AZ
    2013 Prius v wagon
    Yes. The a.m. and both fm's got lost. And I think the losses were when I was not driving. But I will check everything again based on the tips I am receiving.
  10. rdgrimes
    1,740
    446
    New Mexico, USA
    2018 Prius Prime
    On the surface it does sound like bad flash memory in the radio, but you'd want to be triple sure the 12v battery is not at fault. You bought a 2013 car that was sitting on the dealer lot for up to a year, and we know its 12v battery was not tended to. I'd offer the dealer a choice: new head unit for the audio system or a new 12v battery, and let them decide what to do.
    Keep in mind that whatever the dealer decides to do will have a good chance of being the wrong choice. ;)
    Check to see if any other settings for audio, nav, phone etc are being lost. If so it increases the likelihood of a battery issue.
  11. Janet Hart
    AZ
    2013 Prius v wagon
    Sounds like a plan! Thanks.
  12. mikefocke
    3,692
    1,644
    Sanford, NC
    Happened to me yesterday too. At the time it seemed to happen, my wife was trying to find a station playing Xmas music so she was using the seek capability and the tuning capability. Today I noticed it and reset one just to see if it would reset. It did. Wasn't battery as the battery had to be fully charged as we had gone 100 miles when it happened.
  13. Janet Hart
    AZ
    2013 Prius v wagon
    I took the car to the dealer today and the service rep started out saying that it sounded like the battery. The battery, however, tested fine. He said the second guess was the audio system head, as suggested in this thread. But they didn't want to change that out until it happened again, just to rule out my messing up - I guess. I get that. I assume it will happen again and they will replace it then. Whatever happens, I will report vack to this thread as it was very helpful to me. Thanks, again, everyone.
  14. Easy Rider 2
    1,584
    257
    Ocala, FL
    That would not be a smart move on their part.......what's new.
    Given the relative cost of a battery versus a radio head AND the history of bad batteries testing "good" when they aren't, I think the first choice is a no brainer.
    Actually the first choice should be to clean and reseat the connections at the battery and at the radio.
