Loss of coolant 2017 prius, headgasket??
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Adrenaline, Aug 3, 2022.
  1. Adrenaline
    Adrenaline New Member
    Halifax
    Active
    Hi guys I'm new on here, I have a 2017 prius hybrid, recently I have noticed that I have to regularly top up the coolant, I have taken it to several garages but no coolant leaks can be found. The car has done 115k miles. Any advice where I should be looking? And does the headgasket fail on these cars?
    51,985
    welcome!
    it's usually at the exhaust coolant heater loop. i think there is a tsb or extended warranty. call a dealer, or log on to toyota.com/owners
  3. RRxing
    RRxing Senior Member
    2,546
    1,822
    NEPA
    This USA TSB might not cover you due to the mileage limit, but it might. Search to see if there is a Canadian version of this TSB. Good Luck.
    I had this occur on my 2017 Three Touring. It was the exhaust coolant heat exchanger. Took a while for the parts to come in, but was fixed under warranty.
    See attached...
    #3 RRxing, Aug 4, 2022
  4. GregersonIT
    GregersonIT Member
    172
    92
    Livermore
    2020 Prius Prime
    Are you sure it's the coolant you keep refilling? Or the washer fluid? If it's the coolant, I'd suspect someone never changed the fluid and would probably take a really close look at the water pump. The worse case scenario would be the head gasket. But you should see telltale signs of that, white smoke in the tailpipe especially after start, milky oil, etc.
  5. 2010moneypit?
    2010moneypit? Active Member
    314
    122
    Beaumont ca
    What bisco said.
    Very common
  6. Adrenaline
    Halifax
    Active
    Thank you for your response guys, I've been running out of ideas and there is no sludge under oil cap, and it is deffo the radiator expansion tank.
  7. bisco
    51,985
    please let us know the dealers response
  8. MikeDee
    MikeDee Senior Member
    1,580
    597
    San Francisco Bay Area
    Did they do a pressure test?
  9. GregersonIT
    GregersonIT Member
    172
    92
    Livermore
    2020 Prius Prime
    I can see the exchanger at the throttle body being a source of a leak and hard to find as well.
  10. barry mullinax
    barry mullinax Junior Member
    sc
    See TSB T-SB-0135-19 - I didn't know I was losing coolant. it was an internal leak and fried the engine. NO WARNINGS Nothing the car just lost power. It gave me a "Hybrid System Stopped Steering Power Low" right after I suddenly lost power as I turned into a parking lot. I had it towed to my house, hooked up an OB scanner, got a P3190, and replaced 12V battery with no change. The dealership has it now installing an engine, water pump and exhaust to the tune of $10200.00 The car has been very well maintained since new. All servicing has been done at Toyota, where I bought new in 2016. The car gave no warnings whatsoever. I suddenly started losing power and then displayed "Hybrid System Stopped Steering Power Low" and "contact the dealership". You would think if the car was low on coolant or out, the car would give you a notification (IDIOT Light) that the car was getting hot.
  11. barry mullinax
    sc
    See TSB T-SB-0135-19 - I didn't know I was losing coolant. it was an internal leak and fried the engine. NO WARNINGS Nothing the car just lost power. It gave me a "Hybrid System Stopped Steering Power Low" right after I suddenly lost power as I turned into a parking lot. I had it towed to my house, hooked up an OB scanner, got a P3190, and replaced 12V battery with no change. The dealership has it now installing an engine, water pump and exhaust to the tune of $10200.00 The car has been very well maintained since new. All servicing has been done at Toyota, where I bought new in 2016. The car gave no warnings whatsoever. I suddenly started losing power and then displayed "Hybrid System Stopped Steering Power Low" and "contact the dealership". You would think if the car was low on coolant or out, the car would give you a notification (IDIOT Light) that the car was getting hot. have dealership check the part number on the exhaust
  12. Mendel Leisk
    41,497
    I remember driving DIL's Sunfire to Costco for tire repair, looking at the dash, muttering "Even this POS has a temp gauge"...:rolleyes:
    ColoradoBoo likes this.
  13. GregersonIT
    GregersonIT Member
    172
    92
    Livermore
    2020 Prius Prime
    Sounds like the head gasket failed, likely due to manufacturing defect. Reduction of power would be it getting hot or the coolant mucking up the bearings on the crankshaft and or both. Eventually, engine will fail in such a scenario.
  14. dacoobob
    dacoobob Member
    83
    46
    Kansas City, MO
    Four Touring
    it was the exhaust heat exchanger causing the "internal leak", not the head gasket.
  15. Mendel Leisk
    41,497
    It might be?
  16. dacoobob
    dacoobob Member
    83
    46
    Kansas City, MO
    Four Touring
    the poster referenced TSB T-SB-0135-19, which is the one about exhaust heat exchanger failure.
  17. douglasjre
    douglasjre Senior Member
    2,181
    720
    Null, NL
    Do diagnostics=No diagnosis
  18. Paprius9
    Paprius9 Junior Member
    22
    Pennsylvania
    Did you even get a diagnosis? I have the same car, same miles and same problem. A few trips to the dealer. No fix. I’m at a loss.
  19. bisco
    51,985
    sounds like the heat exchanger. dealers are clueless
    T-SB-0135-19
    #19 bisco, Oct 22, 2022
  20. Paprius9
    22
    Pennsylvania
    I agree - they are clueless! I did share the service bulletin with them and they said they didn’t see any coolant in the exhaust system. Yesterday I took a long trip and saw puffs of white smoke on hard acceleration. I am adding maybe a cup of coolant a week! Should I take it to a independent mechanic and have them do the bypass?
